I’m curious how I would go about reporting an issue with/requesting content be added to the Plex Movie agent. Specifically, there are several “Sing Along” versions of movies in the DB (for example, Encanto, Tangled, etc.), and so I was hoping something similar could be added for Wicked, but I can’t find any contact information for the maintainers. Is anyone aware of how such a group could be contacted?
If those are separate instances (according to the rules of the underlying repository), you can sign-up and create the records yourself.
That being said… I believe you’re actually dealing with a different Edition of the same movies – they’re not entirely different releases, are they?
https://support.plex.tv/articles/multiple-editions/
Ahhh ok, so “Plex Movie” is really just a frontend for TMDB? Thanks for clarifying. Will check out their rules and update if appropriate.
No, but it’s using TMDb data as one of its sources.
