Request failed with status code 442
Hello anyone know what happen with this error code when i try to grant access a friend to my server?
Server Version#:
Could be you’re failing to share with that user because it’s exceeding the limit / max amount of shares?!
ohhh! is there a max amount of share? by default? or can i put this number, tx for help
Nothing you can set/change.
Keep in mind Plex is designed for personal use and sharing with family / close friends.
