I use both Sil Dust OTA & Cable tuners and want to view/DVR content from both tuners. Presently only use of one is possible. I.E. if you start by adding a PRIME/cable tuner you will not be able include all found channels from the OTA/Dual tuner.
Many wasted research and config HOURS on this lacking feature.
Otherwise the product ROCKS!
I would like to add that Media Center in the past had the simple ability to clearly show programming from both tuners OTA and Cable. Presently, PLEX Server allows both tuners to be in the config however the programming guide for each tuner type can and does present inaccurate data for some channels. Also the OTA channels are not show as XXX.X channel formatted numbers.
