Plex Media Server 0.9.16.3
Can the sample rate be limited when transcoding HD FLAC files? I’m running into an issue playing 24/96kHz FLAC files in the Plex web interface. I assume this issue will arise on any device which doesn’t natively support FLAC.
Mar 24, 2016 11:07:47 [0x7fd7597fd700] DEBUG - Updating part with ID=68846 [/data/audio/vinyl/Ween - 1992 - Pure Guava [FLAC 24.96]/01 Little Birdy.flac]
Mar 24, 2016 11:07:47 [0x7fd7597fd700] DEBUG - It took 0.0 sec to serialize a list with 1 elements.
Mar 24, 2016 11:07:47 [0x7fd767bfe700] DEBUG - Completed: [127.0.0.1:35116] GET /library/metadata/53650 (14 live) GZIP 6ms 965 bytes 200
Mar 24, 2016 11:07:47 [0x7fd758ffc700] DEBUG - MDE: analyzing media item 68845
Mar 24, 2016 11:07:47 [0x7fd758ffc700] DEBUG - MDE: Little Birdy: Direct Play is disabled
Mar 24, 2016 11:07:47 [0x7fd758ffc700] DEBUG - MDE: Little Birdy: no direct play music profile exists for http/flac/flac
Mar 24, 2016 11:07:47 [0x7fd758ffc700] DEBUG - MDE: Little Birdy: selected media 0 / 68845
Mar 24, 2016 11:07:47 [0x7fd758ffc700] DEBUG - Cleaning directory for session w0t6qgeogm2f0f6r ()
Mar 24, 2016 11:07:47 [0x7fd758ffc700] DEBUG - Starting a transcode session w0t6qgeogm2f0f6r at offset -1.0 (state=2)
Mar 24, 2016 11:07:47 [0x7fd758ffc700] DEBUG - [Universal] Using local file path instead of URL: /data/audio/vinyl/Ween - 1992 - Pure Guava [FLAC 24.96]/01 Little Birdy.flac
Mar 24, 2016 11:07:47 [0x7fd758ffc700] DEBUG - TranscodeJobManager: [Running] onTranscodeSessionStarted: w0t6qgeogm2f0f6r
Mar 24, 2016 11:07:47 [0x7fd758ffc700] DEBUG - TranscodeJobManager: [Running] -> [Throttled]
Mar 24, 2016 11:07:47 [0x7fd758ffc700] DEBUG - Job running: XDG_CACHE_HOME='/var/lib/plex/Plex Media Server/Cache/' XDG_DATA_HOME='/opt/plexmediaserver/Resources/' '/opt/plexmediaserver/Resources/Plex New Transcoder' '-i' '/data/audio/vinyl/Ween - 1992 - Pure
Guava [FLAC 24.96]/01 Little Birdy.flac' '-map' '0:0' '-codec:0' 'libmp3lame' '-ar:0' '96000' '-channel_layout:0' 'stereo' '-q:0' '2' '-f' 'mp3' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' '-' '-start_at_zero' '-copyts' '-y' '-no$
tats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/w0t6qgeogm2f0f6r/progress'
Mar 24, 2016 11:07:47 [0x7fd765bff700] INFO - [Transcoder] Input #0, flac, from '/data/audio/vinyl/Ween - 1992 - Pure Guava [FLAC 24.96]/01 Little Birdy.flac':
Metadata:
track : 1
ALBUM : Pure Guava
DATE : 1992
TITLE : Little Birdy
ARTIST : Ween
Duration: 00:03:29.87, start: 0.000000, bitrate: 3184 kb/s
Stream #0:0, 120, 1/96000: Audio: flac, 96000 Hz, stereo, s32 (24 bit)
Stream #0:1, 1, 1/90000: Video: png, rgba(pc), 1200x1200 [SAR 2835:2835 DAR 1:1], 90k tbr, 90k tbn, 90k tbc
Metadata:
comment : Cover (front)
title : front.png
Mar 24, 2016 11:07:47 [0x7fd758ffc700] DEBUG - [FFMPEG] Duration: 209
Mar 24, 2016 11:07:47 [0x7fd758ffc700] DEBUG - Read line, and done: 1
Mar 24, 2016 11:07:47 [0x7fd758ffc700] DEBUG - Started session successfully: w0t6qgeogm2f0f6r
Mar 24, 2016 11:07:47 [0x7fd766bff700] DEBUG - Started universal transcode output thread
Mar 24, 2016 11:07:47 [0x7fd759ffe700] ERROR - [Transcoder] [libmp3lame @ 0x2be5300] Specified sample rate 96000 is not supported
Mar 24, 2016 11:07:47 [0x7fd7597fd700] INFO - [Transcoder] Output #0, mp3, to 'pipe:':
Metadata:
plex.duration : 209.871
plex.total_duration: 209.871
Stream #0:0, 0, 0/0: Audio: mp3, 0 channels, 128 kb/s
Metadata:
encoder : Lavc56.41.100 libmp3lame
Mar 24, 2016 11:07:47 [0x7fd765bff700] ERROR - [Transcoder] Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
Mar 24, 2016 11:07:47 [0x7fd759ffe700] ? - [Transcoder]
Mar 24, 2016 11:07:47 [0x7fd766bff700] DEBUG - Universal transcode session finished reading output.
Mar 24, 2016 11:07:47 [0x7fd766bff700] DEBUG - Finished universal transcode output thread
It’s apparent that the sample rate of the FLAC file is passed directly into ffmpeg and piped into the LAME. LAME is having issues with the file’s sample rate, so it throws an error and moves on.
Attempting a similar command directly (96000), throws the same error:
ffmpeg -i /data/audio/vinyl/Ween\ -\ 1992\ -\ Pure\ Guava\ \[FLAC\ 24.96\]/01\ Little\ Birdy.flac -map 0:0 -codec libmp3lame -ar 96000 -channel_layout stereo -q 2 -f mp3 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 - -start_at_zero -copyts -y
while adjusting the sample rate (48000), works as expected:
ffmpeg -i /data/audio/vinyl/Ween\ -\ 1992\ -\ Pure\ Guava\ \[FLAC\ 24.96\]/01\ Little\ Birdy.flac -map 0:0 -codec libmp3lame -ar 48000 -channel_layout stereo -q 2 -f mp3 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 - -start_at_zero -copyts -y
