Request to fix Hunter x Hunter meta tags
The plex database currently organizes Hunter x Hunter 2011 into 3 volumes, however the show is actually organized by arcs or seasons, of which there are 6, shown here - Hunter × Hunter (2011 TV series) - Wikipedia
Is there any way for plex to fix this?
Have you already checked that episode organization against The Movie Database or TheTVDb? Plex isn’t using information from Wikipedia.
If your desired ordering is available on those two, you can adjust the show’s entry in your library to prefer that specific order (TMDb, TVDB (Aired), TVDB (DVD), TVDB (Absolute)) → see :pencil2: > Advanced > Episode ordering
The “arc order” is existing on TheTVDB.
However, Plex cannot use any of those new orderings except the 3 above mentioned.
@tom80H ok i tried that but for some reason even though the TVDB has the “arc order” on their site which accurately labels everything, for some reason it doesn’t show up on the drop down under advanced. any way i could refresh it or something? The info is there, but plex isn’t seeing it for some reason.
see above:
There’s a feature suggestion to add support to those flexible categories.
