Resetting all display names
Server Version#: 1.27.2.5929
Player Version#: 1.47.1.3086-6c3d964f
Hi, I would like to reset all the display names I could have changed but not the other datas.
I tried to select all my files (really long because there is no select all button) and click twice on the lock for the display name, thinking it would “release” it for every file, but it did not.
Is there a way to do it ?
Thank you
What exactly do you mean by “display name”?
I’m talking about the title, but not the sorting one, sorry.
You can actually select several posters at once. Depending on the size of your library, this could already work for you:
If your library is quite large (i.e. over several hundred items), you might want to access the Plex server API instead. Use the method dexcribed in here, but use title.locked=0 instead of thumb.locked=0 in the query string:
The first method is the one I used, by selecting everything, but it didn’t unlock.
I just used the second method (with 6 libraries and the 4 types), refreshed the metadatas and it worked, and it kept the title for organising. Thank you very much :slight_smile:
