I’ have a QNAP TS-832X runing with QTS firware 4.3.5.0728
Until now I’m running this version (Alpha) : PlexMediaServer-1.13.6.176-dd1845234-aarch64.qpkg
Downloaded here : QNAP [aarch64 / ARMv8]
[/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer] # ./plex.sh start
Starting Plex Media Server...
[/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer] # ./Plex Media Server: error while loading shared libraries: libcurl.so: ELF load command alignment not page-aligned
If it can help :
[/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer] # cat /proc/cpuinfo
processor : 0
model name : Annapurna Labs Alpine AL324 Quad-core ARM Cortex-A57 CPU @ 1.70GHz
Features : fp asimd evtstrm aes pmull sha1 sha2 crc32
CPU implementer : 0x41
CPU architecture: 8
CPU variant : 0x1
CPU part : 0xd07
CPU revision : 3
processor : 1
CPU architecture: 8
CPU variant : 0x1
CPU part : 0xd07
CPU revision : 3
processor : 2
CPU architecture: 8
CPU variant : 0x1
CPU part : 0xd07
CPU revision : 3
processor : 3
CPU architecture: 8
CPU variant : 0x1
CPU part : 0xd07
CPU revision : 3
Confirm for me that Installing the package FAILS ?
If true, then the file itself is damaged from the download or QTS is fubar (VERY unlikely).
Browsers are 99% of the problem with getting bad downloads. Safari is notorious for it.
The safest way I know is to go to the link you want to download, Right-click, Save file/link as and let it show you the actual file name.
QNAP is unique in that it’s a SHAR (shell archive). Some browsers will think it’s a text file because it has a text header on it (shell script). This is why forcing the save works.
processor : 3
model name : Realtek RTD1295 Quad-Core ARM Cortex-A53 Processor @ 1.4GHz
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
==>> We can read : ARM® v7 1.1GHz dual-core processor
Dual-core processor for high performance
Powered by an ARM® v7 1.1GHz dual-core processor with 1GB DDR3 RAM, the TS-128 delivers an average of 111 MB/s reading and 89 MB/s writing speed for smooth data transmission, concurrent access from multiple users, and home applications. The high-performance and capable TS-128 is ideal for serving as a multimedia center as you can back up or download files without impacting the TS-128’s performance.
