Restart issue and two apple tvs
Two issues I need help with.
  1. When I restart my Mac plexconnect no longer works. I then have to manually run the sudo commons in terminal to get it back up and running. Is there a way to automate the terminal commands on start-up (preferably without having to enter password, although I know it is a sudo command)?
  2. I have two apple tvs in my house. Plexconnect only will work on one. Is there a way to use pc on both concurrently?
Both of these “issues” have been discussed at length in the forum. There are plenty of solutions for number one depending on your operating system. Do a search to find what would work for you. As for number two, I use two ATVs on one Plexconnect all the time. It should work if you set up things properly, ie, change the DNS on both ATVs.
Both of these "issues" have been discussed at length in the forum. There are plenty of solutions for number one depending on your operating system. Do a search to find what would work for you. As for number two, I use two ATVs on one Plexconnect all the time. It should work if you set up things properly, ie, change the DNS on both ATVs.
Thank you for the reply. I did do a search first and did not find the answer to my questions. Not sure how telling me to search is helpful though. If I am posting it is because I did not find the correct thread. If they have been solved as you are indicating please provide me to the thread as I have not been able to locate it.
Per #2 I did change DNS on both but on the second ATV it just keeps spinning. It never finished the connection to the trailer.app (plex connect).
I guess I was suggesting searching a bit further.
For issue one, if you are on a Mac there is an Applescript option, a launchctl option, and a Platypus App shell option. Search using those terms or go to this thread. I use the Applescript myself.
For issue two, you will probably have to submit a more thorough help request following the guidelines in the "Read Before Posting" thread pinned at the top of this forum.
Rock Star. Thanks. That was helpful!
