Curious, once using plex connect, does one have to do the whole terminal thing and change the DNS on the apple tv every time I want to use it. I mean if I take my computer away from home network come home and reconnect to my wifi do I need run the terminal app? Thanks
Yes you need to run the terminal app for all your ATV apps to function unless you reset the ATV DNS back to automatic, this is because PlexConnect sits in the middle either passing Plex information for the trailers app or passing the usual Apple stuff.
