How can I change my password or remove the ability of another person using my access?
Account Settings. https://app.plex.tv/desktop/#!/settings/account
Choose to sign out of connected devices.
You will have to reclaim your server after changing your password.
If the rogue user is within your own local network, you should see to it that
“List of IP addresses and networks that are allowed without auth” should either be completely empty, or only contains IP adresses which belong to your own devices.
(You need to ensure that these IPs are not getting re-assigned to other devices, so you will either have to configure DHCP address reservations in the settings of your router, or assign local IPs to these devices manually.)
