Hi there,
I’ve been having issues with video playback on the PS3.
The Center/Right channels have been swapped when playing back through the Playstation 3.
Here is a sample file:
General
Unique ID : 1624419648296945647066592612283910857 (0x138DA1277A970F7AC3147DBCA350AC9)
Complete name : D:\Psycho-Pass\[CBM]_Psycho-Pass_-_01_-_Crime_Coefficient_[1080p-AC3]_[AF6D4363].mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 999 MiB
Duration : 22mn 53s
Overall bit rate : 6 102 Kbps
Writing application : Lavf56.36.100
Writing library : Lavf56.36.100 / Lavf56.36.100
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 22mn 53s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 138 r2358 9e941d1
Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=72 / rc=crf / mbtree=1 / crf=15.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC
Duration : 22mn 53s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Frame rate : 46.875 fps (1024 spf)
Compression mode : Lossy
Delay relative to video : -292ms
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 22mn 53s
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 3 channels
Channel positions : Front: L R, LFE
Frame rate : 31.250 fps (1536 spf)
Stream size : 105 MiB (10%)
Language : Japanese
Default : Yes
Forced : No
This was recoded from AC3 to AAC (fAAD) on the english channel, but the problem persists. Playback over optical through MPC exhibits correct playback through the same reciever.
Some videos, encoded from sources such as Blu-Ray, do not exhibit this issue.
The Japanese track on this video does not exhibit this issue.
I can provide more information as needed.
