S2s_watches Fix
Server Version#:1.42.2.10156Player Version#: ALL
DSM Version : DSM 7.2.2-72806 Update 3 - DS2419
I’m currently experiencing an issue with my Plex Media Server on Synology:
  • Indexing no longer works: New images and metadata for movies and TV shows are not loading. The yellow loading spinner keeps spinning endlessly.
  • Transcoding has failed: Starting movies and TV shows via the mobile app or browser is no longer possible.
  • Log analysis shows the following error:
[eac3_eae @ 0x7f4a1e071b80] EAE timeout! EAE not running, or wrong folder? Could not read ‘/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/tmp/pms-54587e9e-8905-40e7-9d06-ac69622565fb/EasyAudioEncoder/Convert to WAV (to 8ch or less)/96fa926e-bbdf-4482-987e-9b1c3181d292_15267-0-107.wav’
[Req#4f9e8/Transcode/f729d4c8-ff70-445b-81a4-e74aa5380f97/9a7fdcf3-3d8b-47a3-8c6e-f3b1a2c3dee0] [eac3_eae @ 0x7f4dd1c54b80] error reading output: -5 (I/O error)
[Req#4fa6d/Transcode/f729d4c8-ff70-445b-81a4-e74aa5380f97/9a7fdcf3-3d8b-47a3-8c6e-f3b1a2c3dee0] Error while decoding stream #0:1: I/O error
  • Troubleshooting attempted: I followed the instructions provided in this guide, but unfortunately without success. Authorization and storage space have been checked
  • Additional note for @ChuckPa: Starting from a certain DSM version, it is no longer possible to run scripts directly as the “root” user. Therefore, access via SSH/Putty is required to execute administrative commands properly. the instructions would have to be adjusted
  • Assumption: I suspect the issue is not caused by the number of media files, but possibly by the amount of generated thumbnails. Unfortunately, I lack the Linux knowledge to investigate this further. My English too
@H-o-S
You made a mistake in your Scheduled Task.
Oct 09, 2025 20:35:46.657 [139946295925560] DEBUG - [Notify] Now watching "/volume1/public/Serien/Friends/Staffel 06"
Oct 09, 2025 20:35:46.663 [139946295925560] DEBUG - [Notify] Now watching "/volume1/public/Serien/Friends/Staffel 07"
Oct 09, 2025 20:35:46.668 [139946295925560] DEBUG - [Notify] Now watching "/volume1/public/Serien/Friends/Staffel 08"
Oct 09, 2025 20:35:46.673 [139946295925560] DEBUG - [Notify] Now watching "/volume1/public/Serien/Friends/Staffel 09"
Oct 09, 2025 20:35:46.679 [139946295925560] DEBUG - [Notify] Now watching "/volume1/public/Serien/Friends/Staffel 10"
Oct 09, 2025 20:35:46.683 [139946295925560] DEBUG - [Notify] Now watching "/volume1/public/Serien/Sex and the City"
Oct 09, 2025 20:35:46.683 [139946295925560] DEBUG - [Notify] Now watching "/volume1/public/Serien/Sex and the City/Staffel 1"
Oct 09, 2025 20:35:46.686 [139946295925560] ERROR - [Notify] Failed to add watch for "/volume1/public/Serien/Sex and the City/Staffel 2" (28: No space left on device)
Oct 09, 2025 20:35:46.690 [139946295925560] ERROR - [Notify] Failed to add watch for "/volume1/public/Serien/Sex and the City/Staffel 3" (28: No space left on device)
Oct 09, 2025 20:35:46.694 [139946295925560] ERROR - [Notify] Failed to add watch for "/volume1/public/Serien/Sex and the City/Staffel 4" (28: No space left on device)
Oct 09, 2025 20:35:46.699 [139946295925560] ERROR - [Notify] Failed to add watch for "/volume1/public/Serien/Sex and the City/Staffel 5" (28: No space left on device)
Oct 09, 2025 20:35:46.702 [139946295925560] ERROR - [Notify] Failed to add watch for "/volume1/public/Serien/Sex and the City/Staffel 6" (28: No space left on device)
Oct 09, 2025 20:35:46.706 [139946295925560] ERROR - [Notify] Failed to add watch for "/volume1/public/Serien/Dickinson" (28: No space left on device)
Oct 09, 2025 20:35:46.706 [139946295925560] ERROR - [Notify] Failed to add watch for "/volume1/public/Serien/Dickinson/Staffel 1" (28: No space left on device)
Oct 09, 2025 20:35:46.710 [139946295925560] ERROR - [Notify] Failed to add watch for "/volume1/public/Serien/Dickinson/Staffel 2" (28: No space left on device)
Oct 09, 2025 20:35:46.713 [139946295925560] ERROR - [Notify] Failed to add watch for "/volume1/public/Serien/Dickinson/Staffel 3" (28: No space left on device)
Oct 09, 2025 20:35:46.715 [139946295925560] ERROR - [Notify] Failed to add watch for "/volume1/public/Serien/The Real Ghostbusters" (28: No space left on device)
Oct 09, 2025 20:35:46.716 [139946295925560] ERROR - [Notify] Failed to add watch for "/volume1/public/Serien/The Real Ghostbusters/Staffel 1" (28: No space left on device)
How much memory is installed in the machine?
Show me the task settings as you’ve defined them.
Also please tell me how many folders you have in use (all media).
I will help with the values to put in your script
hy ChuckPa
Memory 20 GB RAM
9448 Folder 65717 Files
hy @ChuckPa
What did I do wrong? If I set the maximum, all subsequent folders can still be read, right?
Sorry I didn’t see this until now.
After setting the values, did you reboot the Syno?
okay thanks .. it works .. how can mark as resolved ?
