Samsung TV tizen app transcodes AC3 and DTS. Using subtitles is not possible if I don’t want to transcode the video too.
Server Dashboard shows direct play but after a while it switch to transcode.
After starting playing the movie:
During playback server CPU usage is unusual high for direct play.
Hi
Thanks for the reply. The server log I’ve already uploaded in the first post. Debug logging without verbose was turned on and server log on Tizen TV was also turned on.
media info XML: movie xml.zip (5.5 KB)
I know right. It’s why I held my little head in my hands for a bit.
There’s so much about subs. Edit you original post and add the subtitles
tag. Hopefully we can get another pair of eyes on this. Try to read those
articles and forum pins about subs.
I have a similar issue on my 49KS8000 however in my case the following happens always in sequence but not always at the same moment (even when replaying the same video it sometimes start after a few minutes and sometimes it is 15 minutes but always the same sequence of issues):
Subtitle not showing or dropping out for some sentences.
Freezing of picture and audio (complete freeze)
Hard exit required from App and restart required before being able to navigate again
This issue has not been there when I bought the TV and installed plex at the time. I am not sure when it began but seemingly this year. I checked already that indeed it is was always UTF8 srt and I only have MKV and mp4 files generating this issue. Up to now it seems limited to HD (720p and 1080p).
Not able to try the build of the post that would hold the fix because it says it is not compatible with my NAS (Synology DS218+).
Honestly I loved the convenience of Plex on my Smart TV and threw out my mediaplayer to limit the number of devices. Now that it is not working anymore I am not able to use it anymore. Please indeed look for a fix. I will try to simulate the problem again with a log file and upload it.
