Server Version#: 1.14.1.5488
Player Version#:4.5.1
Samsung TV auto-upgraded to version 4.5.1 and I can’t find folder view anywhere? Can anyone help???
Yes, it’s not obvious because the “links” on the screen look more like labels.
First, make sure you’ve selected Library and then click on the second “label” on the left (usually next to “All”) and you should see “Folder” as a menu choice. In the screenshot below, you would click on “TV Shows”.
Thanks. The way I got to folders was to first select library. But make sure you are not in the LIST view in the library. You must be in the GRID view. Then you access the folder view by clicking on “TV SHOWS” . Then switch back to LIST VIEW.
True enough, if you’re not in grid view, then you won’t see any of those filtering options.
