Samsung smart tv playlists gone
Server Version#:1.14.1
Player Version#: plex for samsung 3.84.2
Two weeks ago my playlist stoped appearing in my player on samsung smart tv. I see them on the server, even if I create some new playlist it does not appear on the player.
I see there are other people who had the ssme problem or similar. Is there a way to get them back?
Same here. Can’t find my playlists.
End of March - still reply? Surely someone knows either a workaround or when a fix is coming.
Same here. Cannot find playlists on my Samsung Tizen TV anywhere. What gives?
I love Plex and use it all the time, unfortunately I have the same problem regarding no playlists on Samsung TV.
I have just been playing around with the TV app and have just found a work around.
On the Home screen of the app on the top right hand side you will find your user icon,
click on user icon,
click on settings,
on the main settings tab at the top, there will be a check box labelled Preview the new Plex experience,
go across and tick the box,
go back across to main and exit settings menu using the back button of your remote.
You will now have a new and probably experimental Plex layout.
on the left hand side scroll down until you see the playlist folder.
Hopefully that will work for you
