Save filters on a per-library basis
I would like the ability to save filters and to access saved ones as quickly and easy as possible.
And, maybe, the ability to share filters as libraries for friends.
Others have mentioned Playlists as a way of saving filters, but they are not a good substitute.
Saved Filters should just be available to easily filter the current Library view — i.e. they should be within the Library they apply to, not off in Playlists.
Saved Filters should be something like Smart Folders in a file system, and should show up under the Library they apply to on the left and/or from a Saved Filter subsection of the Filter Menu — logically, just listed above of below the Custom Filter option, or perhaps in their own menu.
Once you’re in a Saved Filter view, you should be able to easily toggle open and edit it’s search criteria as needed.
Saved Filters should be easily accessed on all devices.
