Ability to Save Filters
Having the ability to safe filters so we can switch between them easily would make the Filter feature so much more powerful. to use.
I tend to setup specific filters for “Happy hardcore between 2010 and 2020’s”
Would be nice if i could save this filter in the Tracks section for example so i can switch between filters more easily, instead of having to reenter my filters every time :slight_smile:
It would turn the filters into a very attractive feature for me and my users.
You can create playlists and collections from filters.
You can even go into these and edit the filters.
I did not know, i will check it out, do these work when new content is added, will these automatically be picked up by the filter and put in the playlist?
I have discovered the feature, Wish i knew this sooner, thanks for the quick reply!
