Saving my organization
Después de las cosas que he aprendido para organizar mis biblitecas, colecciones, etc… y en esto tengo que agradecer casi todo a @JuiceWSA
¿Existe la posibilidad de guardar todo eso para poder recuperar mis preferencias si tuviera que reinstalar, y no tener que empezar de nuevo?
After the things that I have learned to organize my libraries, collections, etc … and in this I have almost everything to thank @JuiceWSA
Is there a possibility to save all that so that I can get my preferences back if I had to reinstall, and not have to start over?
Thanks & regards
Pepe
[moderator edit: if you use https://translate.google.com/ you can raise the chances that you will get a response in the English part of the forum]
Thank you very much @OttoKerner.
I apologize for my lapse.
I’ll get right on it.
Regards
Pepe
Hello again,
I have the following doubt:
To secure all my PLEX configuration, such as collections, metadata, etc. is it sufficient to safeguard the following:
-C:\Users***\AppData\Local\Plex Media Server\Plug-in Support\Databases.
-HKEY_CURRENT_USER Software for Plex, Inc.\Plex Media Server
Windows 10
Thanks & regards
Pepe
No. It must be the full plex data folder.
Thank you again @OttoKerner.
Hello,
To make copy of the complete plex data folder, I have to close PLEX and all services running. But if it assures me what I want, it is worth to do it once a week.
Thanks & regards
You might want to take a look at PSA: Script to back up and restore Plex app data on a Windows system
I’m certainly getting a lot of good help.
I can’t thank you enough.
I have tried to activate the Volume Shadow Copy Service, both in the OS and in applications that include this service.
But it did not work properly.
