I keep having issues with the scanner crashing atleast once a day requiring a reboot for new items to be found. I am unsure what would be causing this or is there is a fix. When I look for the crash report nothing is there.
Here is the actual error: I have verified that this column in the database table
****** PLEX MEDIA SCANNER CRASHED, CRASH REPORT WRITTEN: /config/Library/Application Support/Plex Media Server/Crash Reports/1.23.3.4706-f48049cad/PLEX MEDIA SCANNER/b8dc31ee-b0ab-45e1-ba2c1a8e-963d1a09.dmp
libc++abi: terminating with uncaught exception of type soci::soci_error: sqlite3_statement_backend::prepare: no such column: library_sections.content_changed_at for SQL: select library_sections.id as ‘library_sections_id’, library_sections.library_id as ‘library_sections_library_id’, library_sections.name as ‘library_sections_name’, library_sections.name_sort as ‘library_sections_name_sort’, library_sections.section_type as ‘library_sections_section_type’, library_sections.language as ‘library_sections_language’, library_sections.agent as ‘library_sections_agent’, library_sections.scanner as ‘library_sections_scanner’, library_sections.user_thumb_url as ‘library_sections_user_thumb_url’, library_sections.user_art_url as ‘library_sections_user_art_url’, library_sections.user_theme_music_url as ‘library_sections_user_theme_music_url’, library_sections.created_at as ‘library_sections_created_at’, library_sections.updated_at as ‘library_sections_updated_at’, library_sections.scanned_at as ‘library_sections_scanned_at’, library_sections.user_fields as ‘library_sections_user_fields’, library_sections.query_xml as ‘library_sections_query_xml’, library_sections.query_type as ‘library_sections_query_type’, library_sections.uuid as ‘library_sections_uuid’, library_sections.changed_at as ‘library_sections_changed_at’, library_sections.content_changed_at as ‘library_sections_content_changed_at’ from library_sections where id=?
****** PLEX MEDIA SCANNER CRASHED, CRASH REPORT WRITTEN: /config/Library/Application Support/Plex Media Server/Crash Reports/1.23.3.4706-f48049cad/PLEX MEDIA SCANNER/320d525d-4e28-48de-f60fbcab-fb68a34a.dmp
@ChuckPa I have stopped the server. Cleared out all logs so that these are all new. Started the server. The moment I ran a scan i began seeing crashed messages. Attached are all the logs that were created on startup of scan
So just an update. I seem to have found that if I restart the server and run a full scan I get the error. If I start the server and then run a scan on each library manually I have no issue.
I was on 1.23.3.4706 when I first started to track an issue with scanner crashing.
I attempted to update to the latest beta of 1.23.3.4712 but I also get the scanner error when a full scan happens. As of now I am on 1.23.3.4707 showing as the latest public build and I have had no issues for this entire day. I have restarted several times to see if I could get it to happen again so far nothing.
The moment I upgrade back to the latest beta 1.23.3.4712 it occurs again. So I am gonna just stay on this build for awhile I guess.
Hello, i have the same problem.
I copied the whole Plex folder (it’s a docker container) with the same rights but still I can’t scan anything I have exactly the same error, even with an older Plex version.
So just came to a conclusion. It is not that I went back to the public version that has stopped my error. It is that I have turned off the automatic library scans and manually scanning once a day. So far no error. The moment I turn on automatic scans again and then restarted crash appears in logs again.
I’m sorry I’ve been away from this thread.
I’ve been insanely busy with Synology DSM 7 launch.
If we can find out / track how far it goes before it crashes (maybe in the logs)
then grab the naming / structure ,
and embedded metadata if MP4 / AVI,
I can take that to Engineering and ask for their input.
No worries there. With some testing today I have made a new server with the latest beta and fresh databases so I am running both side by side. One on the 1.23.3.4707 public version and now the test server on 1.23.4.4775. I am going to test it abit more and see if I can can get both to crash again under the same situation. Previously when I was updating I updated to 1.23.3.4712.
Update so far. The test server is not having any issues with crashing on the 1.23.4.4775. I updated my primary server to 1.23.4.4775 as well. Scanner crash as of now seem to have stopped. I can not reproduce. I have reenabled automatic scans on the server. Ran full manual scans and library scans separately. Nothing seems to have just stopped. Gonna keep watching to see if there are any crashes.
For my part it is impossible to scan after a migration from one server to another.
To specify that it is well on the same versions, all the Plex folder is identical to my new server I can launch a video except that I cannot scan any more.
If I turn off my new server and turn on the old one the scan still works.
Great news but also bad. Scanner crashed again but this time on both the test server and the main server without me making any changes or doing anything. An automatic scan triggered then noticed new items were not getting added. My logs are full of crashes. Later tonight when I get off of work I will stop the server. Clear logs. Restart and see if I can reproduce again.
@ChuckPa I have the lastest logs from server version: 1.23.4.4775
I stopped the server. Cleared out all logs. Started server and then ran a full scan. I am not sure if I can find out the info you requested as I do not see a consistent reason in the logs.
The moment I press scan I get the scanner crash messages. It doesn’t always crash, it took about 5 reboots but I was able to successfully run a full scan without a crash and it added new media to the server.
I have started to have this happen again. It will be fine for awhile then just almost daily the scanner will crash causing items to not be added to the libraries. A few restarts and it is ok again for a bit.
