I go thru the “program guide” to add programs to my recording schedule, but they don’t all show up in my scheduled recordings. I go back to check the individual show and the record button is not lit. I re-click it and it still doesn’t show in schedule, and the record button is not highlighted when I check again. What’s up?
Are you selecting “New Airings Only” or “New and Repeat Airings” when scheduling the recordings?
If selecting “New Airings Only” are you sure the shows you are expecting to record are not repeat airings?
I had it set for new and repeat. I think the problem is the program guide, it doesn’t have the shows listed.
If the program guide doesn’t have the shows then there wouldn’t be any record buttons beside shows/episodes to click?
Some screenshots showing what you are talking about might help and might need to check logs to see if there are any messages displayed.
It’s the program guide. The TV Guide app on my phone doesn’t have the right shows listed either. It would be nice if you could just set it to record like we use to set VCRs. Enter the channel to record, start and stop time, and it could record whatever came on.
