Are Program Guide and Recording Scheduling not using the same data?
Using a HD HomeRun Extend, trying to setup recordings for my wife.
The Ellen show does have episodes currently airing as new and is seen by the program guide.
DVR does have the channel enabled.
But, when I go to Recording Schedule, it says “No Upcoming Airings”.
If the program guide showed upcoming shows, shouldn’t the schedule have them?
For some reason, we can’t find Big Brother either and it’s coming on a major network. Who knows at this point.
Season 14 Episode 52 was originally aired on 11/16/2016, Episode 114 aired 3/1/2017 so unless you have New and Repeat selected it will not record since these are repeat episodes.
Program Guide only has next 14 days of information so if Big Brother is not airing in the next 2 weeks it will not be found.
I’m dealing with the same issue. Has there been any fix to this?
Any fix to what? If you select New and Repeat it will record all episodes not currently in the library recording to. As was pointed out in my reply to the OP the shows they were trying to record were repeats not new broadcasts.
I’m facing similar problem. Sometimes I schedule a recording, and it’s on right now. But in the Recording schedule, and it says there’s no upcoming airing. And since the last update, there’s a issue that scheduled recording time is different time showing up in the guide. But it’ll get recorded at the right time anyway, but does not showed up as running recording in recording schedule, but I can see tuner is occupied.
Yes, there is something to fix: If you ‘discover’ a show (Downward Dog, for instance) on the day it’s supposed to air, it may not show in the program guide. Yet it shows on the recording schedule. Happened this morning. Tuesday, 8pm ABC. Not in New Episodes Tonight. But discoverable.
