Screensaver starting in background during videos playing
Server Version#: 4.121.1
Player Version#: Plex for Samsung, client version 5.74.0, platform version 7
With some recent update, when a video is playing, the screensaver starts in the background while it is being played. Once you do something like select another audio track in the video, the screensaver goes full screen and you have to press a button to first disable it and then see what you’re choosing. Same happens if you select to fast forward to a next video in the folder - first you will see a screenshot appearing from background. This behavior was not there before some of the updates (not sure which one of them).
Uploading: Plex Media Server Logs_2024-01-10_14-18-20.zip…
Here’s the log file from the server.
A bit of an update. I think this happens when you have put the video on pause for some time and screensaver appeared. After this when you resume the video, it plays, but if you want to change track for example - there will be an above described issue with the screensaver. In short, the screensaver should not behave this way when there’s ongoing activity.
