Afternoon all,
ive spotted an odd bug that has been about since the integration with assistant, previously i used to be able to say
“search plex for x” and it would open plex and search - now it does nothing, just sits at the plex splash screen.
If i say “play x on plex” nothing happens at all!
Nope, this is an issue on both clients in fact, if i call the google assistant on both mobile and TV search used to work, and doesnt now as mentioned in my OP
In order to investigate it, could you share some client logs? You can obtain them in Settings / Help & Support / Debugging / Share debugging data
Thanks in advace
Manufacturer: samsung
Device: dreamlte
Model: SM-G950F
Product: dreamltexx
Version: 7.0
