So this is a general statement, but one I believe to be true.
The search function could use some enhancement.
I say this because on large libraries, the results are often slow, and not optimal. It regularly doesn’t show partial matches (Movie called The Red Rabbit, search for Red Rabbit, no results)
The above is a fake example but shows kind of what I mean.
I suspect it to be two fold. 1. Search scanning index using an unoptimized method and 2. The regex (or similar) method for searching titles is not quite there yet.
I’m sure others can provide input.
I am NOT saying this doesn’t work, and I’m saying nothing bad about the software, just some general feedback.
I can’t speak to the performance on a large library. Mine is relatively small, compared to many users.
But I’m not experiencing the partial match issue you described. For example, I search for ‘vinci,’ and I get “The Da Vinci Code” movie, as well as tracks from the soundtrack album:
