Searching by IMDB information yields no results.
So, it normally works…Tried with this video and this information and it yields nothing.
Plex doesn’t use IMDB. It uses The Movie Database (http://www.themoviedb.org).
I know, yet I am going by their blog when you have issues matching the correct one.
support.plex.tv/hc/en-us/articles/201018497-Fix-Incorrect-Match-Match
Read the bottom portion where it states ‘Tips
It has worked 100% of the time so far, unless you know of a different way, besides the author of the PLEX Blog
http://www.imdb.com/title/tt5594228/
The IMDB ID only works in a Movie type library.
What you have there is an OVA that ties into a tv show.
So, if you are using TheTVDB for your tv shows it would work this way:
/ Anime Series
   / One-Punch Man
      / Specials
         One-Punch Man - s00e07 - The Murder Case that is Too Impossible.ext
see ワンパンマン - TheTVDB.com
I’m going to try your method this evening, even though my other OVA showed up in ‘Movies’ since it is in the Movie DataBase
themoviedb.org/movie/370455-one-punch-man-ova
Oh, wow, I didn’t know that. Sorry.
/ Anime Series
   / One-Punch Man
      / Specials
This totally work! Now I can just move all my Anime ‘Movies’ and under TV Show Specials…spending the next 30 minutes fixing my TV Shows…as long as the misses doesnt get upset…
How do I select that you answered my question? It’s missing…
