Searching within channel
Just wondering if there’s away to make searching for certain shows within channels,( ie: icefilms , letmewatchthis ) easier.
Say for example I’m looking for little Eisensteins
In letmewatchthis I go to L then have to scroll page after page before I get to LI. If this makes sense.
Cheers
Riche
Right now I suggest using the plugins first on a device that allows input like your home computer or an iOS client and then you can use the full search function. Once you find what you want make them a favorite or a saved search (SSPlex). The searched for items will then appear in the Plexconnect interface under favorites or saved searches, respectively.
Ah ok , got it , yeah would be easier that way.
Cheers
