Now you’re on your own. That stuff is incorrigible.
Layers on layers make anything tough,
I’ve shown everything matches ok when Plex is given the right top-level directory to scan at.
I’ve tried to mess about with the database and use the following to change paths but I’m not having much luck…
insert into section_locations
select (select seq from sqlite_sequence where name = 'section_locations') as id, library_section_id, '/data/TV/TV' as root_path, available, scanned_at, created_at, updated_at
from section_locations
where root_path = '/mnt/unionfs/Media/TV/TV';
update sqlite_sequence
set seq = seq + 1
where name = 'section_locations';
UPDATE metadata_items
SET guid= replace(guid, '/mnt/unionfs/Media/TV/TV', '/data/TV/TV')
where guid like '/mnt/unionfs/Media/TV/TV/%.mp4';
UPDATE media_parts
SET file= replace(file, '/mnt/unionfs/Media/TV/TV', '/data/TV/TV')
where file like '/mnt/unionfs/Media/TV/TV/%.mp4';
UPDATE media_streams
SET url= replace(url, '/mnt/unionfs/Media/TV/TV', '/data/TV/TV')
where media_item_id in (select media_item_id from media_parts where file like '/data/TV/TV/%.mp4');
UPDATE media_items
set section_location_id = (select id from section_locations where root_path = '/data/TV/TV')
where id in (select media_item_id from media_parts where file like '/data/TV/TV/%.mp4');```
