Second Screen for Plex
My app is now live on iTunes:
https://appsto.re/i6Bw6St
It connects to your Plex server and shows you info about what you are currently watching with a link to IMDB.
Only 99c, a bargain to solve the first world problem of having to search IMDB.  Less than that extra shot you had in your last Starbucks coffee.
Thanks to the beta testers who helped me with this - I'll be sending out your redemption codes shortly.
Realy a nice App for my iPad…
…but the Actor’s Filmography is always empty 8-/
Is there a fix for this?
Realy a nice App for my iPad...
...but the Actor's Filmography is always empty 8-/
I don't see this myself.  Can you give me some examples of films/actors that have this issue?
the Movie and Cast work well… its the Filmography that is always empty
That is odd - I source data from TMDB and there is data for Sigourney Weaver in there.  I'll investigate further and try to sort out a fix as soon as possible.
Thanks for your feedback!
Ok… hope you can fix it
That´s exactly what i need for my second screen in my HTPC! Can you port it to Windows? That will be very great!
