Seeking assistance with casting sync'ed content
Assistance would really be appreciated. I’m pulling my hair out trying to get this to work.
I’m trying to cast synced content to a TV.
I have a Roku Express attached to the TV
I also have a Chromecast attached to the TV.
I am a PlexPass member
I can play the sync’ed content locally on the tablet.
TV, Roku, Chromecast and tablet are all on the same WiFi network and internet connectivity is all working.
I am remote (as in my primary Plex server is at home and I am traveling away).
I can stream remotely from my home Plex server to the Roku and the Chromecast and all works.
But… When I try to stream content that is sync’d to my tablet (on the same wifi network as the chromecast and the roku), the content never starts playing. It looks like it is going to work. The tablet screen shows like it is remotely playing and seconds are counting away on the tablet screen but the TV just shows a gray screen (chromecast example).
My tablet (Samsung Galaxy Tab S3 runing Android Pie) is also “sharing” content so I tried to connect from the Roku to the Tablet as if it was a server but get the message on the TV screen saying “Phil Tablet is Currently Unavailable”.
I see this in the debug logging on the tablet (i.e. the server I’m trying to connect to with Roku).
12-28 09:35:00.961  i: [pms] /10.3.30.105:65446 - GET /logging
12-28 09:35:04.239  i: Resuming UnoHomeActivity.
12-28 09:35:04.258  i: [device] Setting selected server to Offline version: 1.18.1.2019-c186313fe owned: true home: false videoTranscode: true audioTranscode: false deletion: false class: null
12-28 09:35:04.294  i: Fetching [method:GET] http://127.0.0.1:32500/library/sections/268435461/all?includeCollections=1&includeTypeFirst=1&sort=titleSort&type=2&X-Plex-Token=...DPLT&X-Plex-Container-Start=0&X-Plex-Container-Size=50
12-28 09:35:04.315  i: [pms] /127.0.0.1:40618 - GET /library/sections/268435461/all
12-28 09:35:04.346  i: [FocusService] App focus gained.
12-28 09:35:04.346  i: [InitializationMonitor]                   Focused		(+1601.30s,	+71722.70s)
12-28 09:35:04.346  i: [EventSource] Application focused, connecting...
12-28 09:35:04.352  i: [EventSource] Application focused, connecting...
12-28 09:35:04.353  i: [InitializationMonitor]    ConnectingToNanoEvents		(+0.00s,	+71722.70s)
12-28 09:35:04.353  i: [Sonos] Starting discovery connect event
12-28 09:35:04.358  i: [PubSub] Attempting to connect to plex.tv (user: 126101)
12-28 09:35:04.362  i: [WebSocketApplicationBehaviour] Focus change detected. Focused: true
12-28 09:35:04.371  i: [Sonos] SSDP discover message sent : M-SEARCH * HTTP/1.1
HOST: "239.255.255.250:1900"
MAN: "ssdp:discover"
MX: 1
ST: urn:schemas-upnp-org:device:ZonePlayer:1
12-28 09:35:04.388  i: Fetching [method:GET] https://plex.tv/api/v2/features?auth_token=...DPLT&includeExternalMedia=1
12-28 09:35:04.395  i: Fetching [method:GET] http://127.0.0.1:32500/media/providers?includeStorage=1&includeTypeFirst=1&X-Plex-Token=...DPLT
12-28 09:35:04.396  i: Fetching [method:GET] https://plex.tv/api/v2/companions?auth_token=...DPLT&includeExternalMedia=1
12-28 09:35:04.402  i: [Cast] Application focused, performing active scan.
12-28 09:35:04.426  i: [pms] /127.0.0.1:40621 - GET /media/providers
12-28 09:35:04.470  i: [Sync] Total: 119.1 GB   Limit: 117.5 GB   Used by Sync: 111.0 GB   Free: 6.9 GB   Available 6.5 GB.
12-28 09:35:04.942  i: [Cast] onRouteChanged (description=Chromecast, id=com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, playback stream=-1, playback type=1)
12-28 09:35:04.988  i: [Cast] onRouteChanged (description=Chromecast, id=com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, playback stream=-1, playback type=1)
12-28 09:35:09.412  w: [Sonos] Nearby discovery socket timed out, probably because there aren't devices nearby
12-28 09:35:10.424  i: [Cast] onRouteChanged (description=Chromecast, id=com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, playback stream=-1, playback type=1)
12-28 09:35:11.937  i: [pms] /10.3.30.178:52632 - GET /identity
12-28 09:35:13.720  i: [EventSource] Attempting to connect (user: 126101)
12-28 09:35:13.848  i: Fetching [method:GET] https://plex.tv/api/v2/user/privacy?auth_token=...DPLT&includeExternalMedia=1
12-28 09:35:13.868  i: [EventSource] Attempting to connect (user: 126101)
12-28 09:35:13.888  i: [EventSource] Connected to http://127.0.0.1:49414/:/eventsource/notifications?X-Plex-Token=...DPLT.
12-28 09:35:13.888  i: [InitializationMonitor]     ConnectedToNanoEvents		(+9.54s,	+71732.25s)
12-28 09:35:15.153  i: [Metrics] Correctly fetched privacy map from plex.tv.
12-28 09:35:15.252  i: [Sonos] Checking state of player tv.plex.sonos
12-28 09:35:15.256  i: Fetching [method:GET] https://sonos.plex.tv/resources?X-Plex-Token=...DPLT&X-Plex-Client-Identifier=6735b349884b9660-com-plexapp-android&includeExternalMedia=1
12-28 09:35:15.575  i: [pms] /10.3.30.178:52633 - GET /identity
12-28 09:35:15.856  i: [EventSource] Connected to https://pubsub.plex.tv/sub/eventsource/126101/6735b349884b9660-com-plexapp-android?X-Plex-Token=...DPLT.
12-28 09:35:16.701  i: [pms] /10.3.30.178:52634 - GET /identity
12-28 09:35:17.171  e: Error fetching https://sonos.plex.tv/resources?X-Plex-Token=...DPLT&X-Plex-Client-Identifier=6735b349884b9660-com-plexapp-android:
Forbidden
12-28 09:35:17.185  i: [SonosDeviceManager] Received state 403 for player tv.plex.sonos
12-28 09:35:17.189  i: [Sonos] Updating selected player
12-28 09:35:17.190  i: [Sonos] Using cloud environment tv.plex.sonos
12-28 09:35:17.190  w: [Sonos] Non ready player tv.plex.sonos cannot be added as no nearby speakers have been found
12-28 09:35:24.773  i: [pms] /10.3.30.105:65451 - GET /logging
I also have no Sonos in my setup so not sure what that is about.
When I try and cast from tablet to the Roku I see this in the logs…
12-28 09:41:03.317  i: [pms] /10.3.30.105:65502 - GET /logging
12-28 09:41:15.792  i: [UserAction] Click item For All Mankind (/library/metadata/268712274/children).
12-28 09:41:15.795  i: [Download Item] Downloading item with uri server://local/com.plexapp.plugins.library/library/metadata/268712274?asyncAugmentMetadata=1&includeExternalMetadata=1&includeExtras=1&includePreferences=1&includeRelated=1&includeRelatedCount=0
12-28 09:41:15.798  i: Fetching [method:GET] http://127.0.0.1:32500/library/metadata/268712274?asyncAugmentMetadata=1&includeExternalMetadata=1&includeExtras=1&includePreferences=1&includeRelated=1&includeRelatedCount=0&includeTypeFirst=1&X-Plex-Token=...DPLT
12-28 09:41:15.813  i: [pms] /127.0.0.1:40676 - GET /library/metadata/268712274
12-28 09:41:15.858  i: Fetching [method:GET] http://127.0.0.1:32500/library/sections?includeTypeFirst=1&X-Plex-Token=...DPLT
12-28 09:41:15.866  i: [pms] /127.0.0.1:40678 - GET /library/sections
12-28 09:41:15.868  i: [Remote] Sending message (/player/timeline/subscribe?protocol=http&port=32500&commandID=18) to The Roku
12-28 09:41:15.869  i: Fetching [method:GET] http://10.3.30.178:8324/player/timeline/subscribe?protocol=http&port=32500&commandID=18&X-Plex-Token=...DPLT&includeExternalMedia=1
12-28 09:41:15.883  i: Fetching [method:GET] http://127.0.0.1:32500/library/metadata/268712274/children?includeTypeFirst=1&X-Plex-Token=...DPLT
12-28 09:41:15.892  i: [pms] /127.0.0.1:40681 - GET /library/metadata/268712274/children
12-28 09:41:15.969  i: Creating PreplayShowActivity.
12-28 09:41:16.011  i: [pms] /10.3.30.178:52653 - POST /:/timeline
12-28 09:41:16.047  i: [AugmentedContentHelper] Trying to load augmented content without an augmentation key
12-28 09:41:16.055  i: [Boot] PreplayShowActivity took 7ms to run create behaviours.
12-28 09:41:16.064  i: Resuming PreplayShowActivity.
12-28 09:41:19.026  i: [UserAction] Click 'play' button in preplay activity.
12-28 09:41:19.034  i: [PlayQueues] Creating remote PQ.
12-28 09:41:19.035  i: [PlayQueueAPIHelperBase] No item path provided, will generate a new one
12-28 09:41:19.038  i: Fetching [method:POST] http://127.0.0.1:32500/playQueues?continuous=0&includeChapters=1&includeLoudnessRamps=1&includeTypeFirst=1&repeat=0&shuffle=0&type=video&uri=library%3A%2F%2F46e3da072ec70d1f060fc3559ad154a2c7f665cf%2Fdirectory%2F%252Flibrary%252Fsections%252F268435461%252Fall%253Fshow.id%253D268712274%2526sort%253Dseason.index%25252Cepisode.index%25252Cepisode.originallyAvailableAt%2526type%253D4%2526unwatched%253D1&X-Plex-Token=...DPLT
12-28 09:41:19.050  i: [pms] /127.0.0.1:40683 - POST /playQueues
12-28 09:41:19.110  i: [PlayQueueAPIHelperBase] Result container=<MediaContainer mediaTagPrefix="/system/bundle/media/flags/" identifier="com.plexapp.plugins.library" playQueueVersion="1" playQueueID="1879048293" size="10" playQueueSourceURI="library://46e3da072ec70d1f060fc3559ad154a2c7f665cf/directory/%2Flibrary%2Fsections%2F268435461%2Fall%3Fshow.id%3D268712274%26sort%3Dseason.index%252Cepisode.index%252Cepisode.originallyAvailableAt%26type%3D4%26unwatched%3D1" playQueueShuffled="0" playQueueSelectedItemID="1879048830" playQueueSelectedMetadataItemID="268712283" playQueueTotalCount="10" mediaTagVersion="1" playQueueSelectedItemOffset="0" />
12-28 09:41:19.110  w: [RemotePlayQueue] Couldn't find item with PQ ID=null in current window.
12-28 09:41:19.140  i: [MediaBrowserAudioService] onCreate
12-28 09:41:19.143  i: [PlayerService] onCreate
12-28 09:41:19.146  i: [ConnectivityManager] Device is under Wifi
12-28 09:41:19.148  i: [Player] Changing to use remote interface for playback: The Roku
12-28 09:41:19.157  i: [MemoryOptimisationBehaviour] Reducing memory cache.
12-28 09:41:19.158  i: [RefetchCurrentItemBehaviour] Fetching current item
12-28 09:41:19.159  i: [MediaSessionHelper] Starting media session with tag: video
12-28 09:41:19.160  i: Fetching [method:GET] http://127.0.0.1:32500/library/metadata/268712283?includeChapters=1&includeLoudnessRamps=1&includeRelated=1&includeTypeFirst=1&X-Plex-Token=...DPLT
12-28 09:41:19.160  i: [MediaSessionHelper] Creating media session with tag: video
12-28 09:41:19.166  i: [pms] /127.0.0.1:40684 - GET /library/metadata/268712283
12-28 09:41:19.193  i: [MediaSessionBehaviour] Updatating metdata for video, thumb: false
12-28 09:41:19.218  i: [pms] /127.0.0.1:40685 - GET /photo/:/transcode
12-28 09:41:19.225  i: Fetching [method:GET] http://127.0.0.1:32500/security/token?includeTypeFirst=1&scope=all&type=delegation&X-Plex-Token=...DPLT
12-28 09:41:19.238  i: [MediaSessionHelper] Releasing media session with tag: video
12-28 09:41:19.238  i: [MediaSessionHelper] Starting media session with tag: music
12-28 09:41:19.239  i: [MediaSessionHelper] Creating media session with tag: music
12-28 09:41:19.239  i: [pms] /127.0.0.1:40686 - GET /security/token
12-28 09:41:19.254  i: [RefetchCurrentItemBehaviour] Fetched current item, notifying listeners
12-28 09:41:19.254  e: Error fetching http://127.0.0.1:32500/security/token?includeTypeFirst=1&scope=all&type=delegation&X-Plex-Token=...DPLT:
<html><head><title>Not Found</title></head><body><h1>404 Not Found</h1></body></html>
12-28 09:41:19.257  i: [Remote] Sending message (/player/playback/playMedia?protocol=http&providerIdentifier=com.plexapp.plugins.library&address=10.3.30.177&machineIdentifier=6735b349884b9660-com-plexapp-android&offset=0&port=32500&containerKey=%2FplayQueues%2F1879048293%3Fown%3D1%26repeat%3D0%26window%3D200&type=video&commandID=19&key=%2Flibrary%2Fmetadata%2F268712283) to The Roku
12-28 09:41:19.261  i: Fetching [method:GET] http://10.3.30.178:8324/player/playback/playMedia?protocol=http&providerIdentifier=com.plexapp.plugins.library&address=10.3.30.177&machineIdentifier=6735b349884b9660-com-plexapp-android&offset=0&port=32500&containerKey=%2FplayQueues%2F1879048293%3Fown%3D1%26repeat%3D0%26window%3D200&type=video&commandID=19&key=%2Flibrary%2Fmetadata%2F268712283&X-Plex-Token=...DPLT&includeExternalMedia=1
12-28 09:41:19.276  i: Creating PlayerActivity.
12-28 09:41:19.276  i: [Activity] Resuming the application, attempting to download item and children.
12-28 09:41:19.284  i: [Boot] PlayerActivity took 7ms to run create behaviours.
12-28 09:41:19.285  i: [PlayerActivity] Creating fragment
12-28 09:41:19.290  i: [Player][DimensionsLayout] Resizing: 100 x 100
12-28 09:41:19.299  i: [ConnectivityManager] Device is under Wifi
12-28 09:41:19.316  i: Fetching [method:GET] https://plex.tv/api/v2/user/profile?auth_token=...DPLT&includeExternalMedia=1
12-28 09:41:19.333  i: [MediaSessionBehaviour] Updatating metdata for video, thumb: true
12-28 09:41:19.452  i: [pms] /10.3.30.178:52654 - GET /identity
12-28 09:41:19.499  i: Resuming PlayerActivity.
12-28 09:41:19.551  i: [Player][View] Layout has been measured with a size of 1536 x 2006 (1536 x 2006).
12-28 09:41:19.553  i: [SystemUIBehaviour] Showing the system user-interface.
12-28 09:41:19.554  i: [EngineEventManager] onPlaybackStarted: 1879048830
12-28 09:41:19.557  i: [MediaSessionHelper] Releasing media session with tag: music
12-28 09:41:19.558  i: [MediaSessionHelper] Starting media session with tag: video
12-28 09:41:19.558  i: [MediaSessionHelper] Creating media session with tag: video
12-28 09:41:19.572  i: [pms] /127.0.0.1:40688 - GET /photo/:/transcode
12-28 09:41:19.574  i: [pms] /10.3.30.178:52655 - GET /media/providers
12-28 09:41:19.575  i: [TranscodeSession] Media choice updated
12-28 09:41:19.576  i: [TranscodeSession] Updating session status
12-28 09:41:19.576  i: [Player] onPlaybackStarted
12-28 09:41:19.577  i: [PlayQueueBehaviour] Clearing audio PQ because video playback has started.
12-28 09:41:19.583  i: [Remote Notification] - Cancelling notification for ed7ac6ad0b3bfa3e0d4897333f7259bc, type music
12-28 09:41:19.584  i: [Remote Notification] - Updating notification for ed7ac6ad0b3bfa3e0d4897333f7259bc, type video
12-28 09:41:19.594  i: [Remote Notification] - Cancelling notification for ed7ac6ad0b3bfa3e0d4897333f7259bc, type music
12-28 09:41:19.595  i: [Remote Notification] - Cancelling notification for ed7ac6ad0b3bfa3e0d4897333f7259bc, type photo
12-28 09:41:19.627  i: [Remote Control Manager] - Updating player (The Roku) for S01 E01.
12-28 09:41:19.657  i: Cache hit for item art.
12-28 09:41:19.678  i: [pms] /127.0.0.1:40689 - GET /photo/:/transcode
12-28 09:41:19.735  i: [TranscodeSession] Direct Play
12-28 09:41:19.739  w: [PlayHelper] null PlexItem passed in when getting PlayerClass. Incorrect player may be selected.
12-28 09:41:19.755  i: [Player][View] Layout has been measured with a size of 1536 x 2048 (1536 x 2048).
12-28 09:41:19.788  i: [pms] /127.0.0.1:40690 - GET /photo/:/transcode
12-28 09:41:20.149  w: [PlayHelper] null PlexItem passed in when getting PlayerClass. Incorrect player may be selected.
12-28 09:41:39.575  i: [pms] /10.3.30.105:65504 - GET /logging
And when I try and cast to the Chromecast I see this in the logs…
12-28 09:46:20.394  i: [pms] /10.3.30.105:49180 - GET /logging
12-28 09:46:35.550  i: [Cast] Starting aggressive device scanning.
12-28 09:46:35.677  i: [Cast] onRouteChanged (description=Chromecast, id=com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, playback stream=-1, playback type=1)
12-28 09:46:40.978  i: [PlayerManager] Setting selected player: Away TV
12-28 09:46:40.987  i: [device] Setting selected server to com.plexapp.plex.net.remote.b@2dd12822
12-28 09:46:40.988  i: [Cast] - Connecting to CastDeviceController.
12-28 09:46:41.023  i: [Remote Notification] - Cancelling notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type video
12-28 09:46:41.024  i: [Remote Notification] - Cancelling notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type music
12-28 09:46:41.024  i: [Remote Notification] - Cancelling notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type photo
12-28 09:46:41.024  i: [Remote Control Manager] - Updating player (Away TV) by cancelling.
12-28 09:46:41.025  i: [Remote Control Manager] Cancelling
12-28 09:46:41.060  i: [Cast] Stopping aggressive device scanning.
12-28 09:46:41.102  i: [Cast] onRouteChanged (description=Chromecast, id=com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, playback stream=-1, playback type=1)
12-28 09:46:41.250  i: [Cast] Device connected.
12-28 09:46:41.253  i: [Remote Notification] - Cancelling notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type video
12-28 09:46:41.253  i: [Remote Notification] - Cancelling notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type music
12-28 09:46:41.253  i: [Remote Notification] - Cancelling notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type photo
12-28 09:46:41.253  i: [Remote Control Manager] - Updating player (Away TV) by cancelling.
12-28 09:46:41.254  i: [Remote Control Manager] Cancelling
12-28 09:46:42.159  i: [Cast] onRouteChanged (description=Plex Cast, id=com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, playback stream=-1, playback type=1)
12-28 09:46:42.875  i: [Cast] onRouteChanged (description=Plex Cast, id=com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, playback stream=-1, playback type=1)
12-28 09:46:42.880  i: [Cast] Application launched.
12-28 09:46:42.883  i: [Remote Notification] - Cancelling notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type video
12-28 09:46:42.884  i: [Remote Notification] - Cancelling notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type music
12-28 09:46:42.885  i: [Remote Notification] - Cancelling notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type photo
12-28 09:46:42.888  i: [Remote Control Manager] - Updating player (Away TV) by cancelling.
12-28 09:46:42.896  i: [Remote Control Manager] Cancelling
12-28 09:46:42.925  w: [Cast] Couldn't extract current time from incoming message.
12-28 09:46:42.925  i: [Cast] Reporting state change from 1 to 0.
12-28 09:46:42.926  i: [Cast] Unknown player state
12-28 09:46:42.926  i: [Remote Notification] - Cancelling notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type video
12-28 09:46:42.927  i: [Remote Notification] - Cancelling notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type music
12-28 09:46:42.927  i: [Cast] Unknown player state
12-28 09:46:42.927  i: [Remote Notification] - Cancelling notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type photo
12-28 09:46:42.927  i: [Remote Control Manager] - Updating player (Away TV) by cancelling.
12-28 09:46:42.928  i: [Remote Control Manager] Cancelling
12-28 09:46:42.934  i: [Cast] onRouteChanged (description=Plex Cast, id=com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, playback stream=-1, playback type=1)
12-28 09:46:43.269  i: [Cast] onRouteChanged (description=Plex, id=com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, playback stream=-1, playback type=1)
12-28 09:46:46.147  i: [pms] /10.3.30.132:54222 - OPTIONS /library/arts
12-28 09:46:46.197  i: [pms] /10.3.30.132:54223 - GET /library/arts
12-28 09:46:49.750  i: [UserAction] Click item For All Mankind (/library/metadata/268712274/children).
12-28 09:46:49.754  i: [Download Item] Downloading item with uri server://local/com.plexapp.plugins.library/library/metadata/268712274?asyncAugmentMetadata=1&includeExternalMetadata=1&includeExtras=1&includePreferences=1&includeRelated=1&includeRelatedCount=0
12-28 09:46:49.756  i: Fetching [method:GET] http://127.0.0.1:32500/library/metadata/268712274?asyncAugmentMetadata=1&includeExternalMetadata=1&includeExtras=1&includePreferences=1&includeRelated=1&includeRelatedCount=0&includeTypeFirst=1&X-Plex-Token=...DPLT
12-28 09:46:49.770  i: [pms] /127.0.0.1:40743 - GET /library/metadata/268712274
12-28 09:46:49.827  i: Fetching [method:GET] http://127.0.0.1:32500/library/sections?includeTypeFirst=1&X-Plex-Token=...DPLT
12-28 09:46:49.836  i: [pms] /127.0.0.1:40745 - GET /library/sections
12-28 09:46:49.850  i: Fetching [method:GET] http://127.0.0.1:32500/library/metadata/268712274/children?includeTypeFirst=1&X-Plex-Token=...DPLT
12-28 09:46:49.858  i: [pms] /127.0.0.1:40747 - GET /library/metadata/268712274/children
12-28 09:46:49.940  i: Creating PreplayShowActivity.
12-28 09:46:50.011  i: [AugmentedContentHelper] Trying to load augmented content without an augmentation key
12-28 09:46:50.020  i: [Boot] PreplayShowActivity took 9ms to run create behaviours.
12-28 09:46:50.027  i: Resuming PreplayShowActivity.
12-28 09:46:50.032  i: [Cast] Sending mirror.
12-28 09:46:50.034  i: Fetching [method:GET] http://127.0.0.1:32500/security/token?includeTypeFirst=1&scope=all&type=delegation&X-Plex-Token=...DPLT
12-28 09:46:50.042  i: [pms] /127.0.0.1:40749 - GET /security/token
12-28 09:46:50.053  e: Error fetching http://127.0.0.1:32500/security/token?includeTypeFirst=1&scope=all&type=delegation&X-Plex-Token=...DPLT:
12-28 09:46:50.225  i: [pms] /10.3.30.132:54224 - OPTIONS /library/metadata/268712274
12-28 09:46:50.236  i: [Cast] Unknown player state
12-28 09:46:50.246  i: [pms] /10.3.30.132:54225 - GET /library/metadata/268712274
12-28 09:46:50.246  i: [Cast] Unknown player state
12-28 09:46:52.400  i: [UserAction] Click 'play' button in preplay activity.
12-28 09:46:52.407  i: [PlayQueues] Creating remote PQ.
12-28 09:46:52.407  i: [PlayQueueAPIHelperBase] No item path provided, will generate a new one
12-28 09:46:52.410  i: Fetching [method:POST] http://127.0.0.1:32500/playQueues?continuous=0&includeChapters=1&includeLoudnessRamps=1&includeTypeFirst=1&repeat=0&shuffle=0&type=video&uri=library%3A%2F%2F46e3da072ec70d1f060fc3559ad154a2c7f665cf%2Fdirectory%2F%252Flibrary%252Fsections%252F268435461%252Fall%253Fshow.id%253D268712274%2526sort%253Dseason.index%25252Cepisode.index%25252Cepisode.originallyAvailableAt%2526type%253D4%2526unwatched%253D1&X-Plex-Token=...DPLT
12-28 09:46:52.422  i: [pms] /127.0.0.1:40750 - POST /playQueues
12-28 09:46:52.479  i: [PlayQueueAPIHelperBase] Result container=<MediaContainer mediaTagPrefix="/system/bundle/media/flags/" identifier="com.plexapp.plugins.library" playQueueVersion="1" playQueueID="1879048294" size="10" playQueueSourceURI="library://46e3da072ec70d1f060fc3559ad154a2c7f665cf/directory/%2Flibrary%2Fsections%2F268435461%2Fall%3Fshow.id%3D268712274%26sort%3Dseason.index%252Cepisode.index%252Cepisode.originallyAvailableAt%26type%3D4%26unwatched%3D1" playQueueShuffled="0" playQueueSelectedItemID="1879048840" playQueueSelectedMetadataItemID="268712283" playQueueTotalCount="10" mediaTagVersion="1" playQueueSelectedItemOffset="0" />
12-28 09:46:52.480  w: [RemotePlayQueue] Couldn't find item with PQ ID=null in current window.
12-28 09:46:52.481  w: [RemotePlayQueue] Couldn't find item with PQ ID=null in current window.
12-28 09:46:52.494  i: [Cast] Unknown player state
12-28 09:46:52.505  i: [Cast] Unknown player state
12-28 09:46:52.533  i: [MediaBrowserAudioService] onCreate
12-28 09:46:52.535  i: [PlayerService] onCreate
12-28 09:46:52.538  i: [ConnectivityManager] Device is under Wifi
12-28 09:46:52.538  i: [Player] Changing to use remote interface for playback: Away TV
12-28 09:46:52.549  i: [MemoryOptimisationBehaviour] Reducing memory cache.
12-28 09:46:52.549  i: [RefetchCurrentItemBehaviour] Fetching current item
12-28 09:46:52.551  i: [MediaSessionBehaviour] Updatating metdata for video, thumb: false
12-28 09:46:52.551  i: Fetching [method:GET] http://127.0.0.1:32500/library/metadata/268712283?includeChapters=1&includeLoudnessRamps=1&includeRelated=1&includeTypeFirst=1&X-Plex-Token=...DPLT
12-28 09:46:52.561  i: [ConnectivityManager] Device is under Wifi
12-28 09:46:52.564  i: Fetching [method:GET] http://127.0.0.1:32500/security/token?includeTypeFirst=1&scope=all&type=delegation&X-Plex-Token=...DPLT
12-28 09:46:52.566  i: [pms] /127.0.0.1:40751 - GET /library/metadata/268712283
12-28 09:46:52.576  i: [MediaSessionBehaviour] Updatating metdata for video, thumb: true
12-28 09:46:52.599  i: [MediaSessionHelper] Releasing media session with tag: video
12-28 09:46:52.603  i: [pms] /127.0.0.1:40752 - GET /security/token
12-28 09:46:52.605  i: [MediaSessionHelper] Starting media session with tag: music
12-28 09:46:52.606  i: [MediaSessionHelper] Creating media session with tag: music
12-28 09:46:52.618  e: Error fetching http://127.0.0.1:32500/security/token?includeTypeFirst=1&scope=all&type=delegation&X-Plex-Token=...DPLT:
12-28 09:46:52.638  i: Creating PlayerActivity.
12-28 09:46:52.638  i: [Activity] Resuming the application, attempting to download item and children.
12-28 09:46:52.645  i: [Boot] PlayerActivity took 8ms to run create behaviours.
12-28 09:46:52.648  i: [PlayerActivity] Creating fragment
12-28 09:46:52.652  i: [Player][DimensionsLayout] Resizing: 100 x 100
12-28 09:46:52.658  i: [ConnectivityManager] Device is under Wifi
12-28 09:46:52.674  i: Fetching [method:GET] https://plex.tv/api/v2/user/profile?auth_token=...DPLT&includeExternalMedia=1
12-28 09:46:52.708  i: [pms] /10.3.30.132:54226 - OPTIONS /log
12-28 09:46:52.752  i: [Cast] Unknown player state
12-28 09:46:52.756  i: [Cast] Unknown player state
12-28 09:46:52.834  i: Resuming PlayerActivity.
12-28 09:46:52.871  i: [pms] /10.3.30.132:54227 - OPTIONS /playQueues/1879048294
12-28 09:46:52.899  i: [Player][View] Layout has been measured with a size of 1536 x 2006 (1536 x 2006).
12-28 09:46:52.902  i: [RefetchCurrentItemBehaviour] Fetched current item, notifying listeners
12-28 09:46:52.902  i: [Cast] Unknown player state
12-28 09:46:52.904  i: [MenuSheetHud] Item changed (and fetched), invalidating settings...
12-28 09:46:52.906  i: [SystemUIBehaviour] Showing the system user-interface.
12-28 09:46:52.912  i: [pms] /10.3.30.132:54228 - POST /log
12-28 09:46:53.014  w: [Cast] Couldn't extract current time from incoming message.
12-28 09:46:53.022  i: [pms] /10.3.30.132:54229 - GET /playQueues/1879048294
12-28 09:46:53.218  i: [Player][View] Layout has been measured with a size of 1536 x 2048 (1536 x 2048).
12-28 09:46:54.020  i: [pms] /10.3.30.132:54230 - POST /log
12-28 09:46:54.557  i: [pms] /10.3.30.132:54231 - OPTIONS /library/metadata/268712283
12-28 09:46:54.569  i: [Cast] Reporting state change from 0 to 2.
12-28 09:46:54.573  i: [EngineEventManager] onPlaybackStarted: 1879048840
12-28 09:46:54.587  i: [MediaSessionHelper] Releasing media session with tag: music
12-28 09:46:54.589  i: [MediaSessionHelper] Starting media session with tag: video
12-28 09:46:54.590  i: [MediaSessionHelper] Creating media session with tag: video
12-28 09:46:54.598  i: [TranscodeSession] Media choice updated
12-28 09:46:54.599  i: [TranscodeSession] Updating session status
12-28 09:46:54.599  i: [Player] onPlaybackStarted
12-28 09:46:54.602  i: [PlayQueueBehaviour] Clearing audio PQ because video playback has started.
12-28 09:46:54.603  i: [Remote Notification] - Cancelling notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type music
12-28 09:46:54.603  i: [Remote Notification] - Updating notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type video
12-28 09:46:54.610  i: [Remote Notification] - Cancelling notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type music
12-28 09:46:54.610  i: [Remote Notification] - Cancelling notification for com.google.android.gms/.cast.media.CastMediaRouteProviderService:76c75a862cc965731f32015c208a215a, type photo
12-28 09:46:54.631  i: [Remote Control Manager] - Updating player (Away TV) for S01 E01.
12-28 09:46:54.631  i: Cache hit for item art.
12-28 09:46:54.638  i: [TranscodeSession] Direct Play
12-28 09:46:54.639  w: [PlayHelper] null PlexItem passed in when getting PlayerClass. Incorrect player may be selected.
12-28 09:46:54.672  i: [pms] /10.3.30.132:54232 - GET /photo/:/transcode
12-28 09:46:54.674  i: [pms] /10.3.30.132:54233 - POST /log
12-28 09:46:54.791  i: [pms] /10.3.30.132:54234 - GET /photo/:/transcode
12-28 09:46:54.863  w: [PlayHelper] null PlexItem passed in when getting PlayerClass. Incorrect player may be selected.
12-28 09:46:54.896  i: [pms] /10.3.30.132:54235 - GET /library/metadata/268712283
12-28 09:46:55.574  i: [pms] /10.3.30.132:54236 - POST /log
12-28 09:46:55.716  i: [pms] /10.3.30.132:54237 - OPTIONS /video/:/transcode/universal/decision
12-28 09:46:55.802  i: [pms] /10.3.30.132:54238 - POST /log
12-28 09:46:55.814  i: [pms] /10.3.30.132:54239 - GET /video/:/transcode/universal/decision
12-28 09:46:55.976  i: [pms] /10.3.30.132:54240 - POST /log
12-28 09:46:56.086  w: [Cast] Couldn't extract current time from incoming message.
12-28 09:46:56.096  w: [Cast] Couldn't extract current time from incoming message.
12-28 09:46:56.137  i: [pms] /10.3.30.132:54241 - OPTIONS /:/timeline
12-28 09:46:56.225  i: [pms] /10.3.30.132:54242 - POST /log
12-28 09:46:56.706  i: [pms] /10.3.30.132:54243 - GET /:/timeline
12-28 09:47:05.692  i: [HomeHubsManager] Item content source server://local/com.plexapp.plugins.library has volatile hubs: marking as stale.
12-28 09:47:12.673  i: [pms] /10.3.30.105:49189 - GET /logging
Hi. I am having the same problem for months now. Apparently there are others too with the same problem.
There hasn’t been a single response from Plex officials over this issue.
