Seeking guidance on a PLEX/NAS build, that will also become home file storage. The primary goal is to have a media repository that is fast enough to handle 5 or 6 streams at max (1080p) (Realistically maybe only 3 streams, but trying to hit the max goal if possible because I would like to have overhead to spare)
My initial plan was to have a PC with a supported CPU for hardware accelerated transcoding for the PMS, and have the media stored on a fast NAS such as a Synology DS1618+. I have a Meraki MS220-8P for switching duties, and was going to aggregate two ports on that and two ports on the Synology to ensure I had bandwidth to spare on the media, but then I discovered that unless I somehow find a way to get NIC teaming to work in a non server PC I’m going to be stuck with the bottleneck at the PC.
So then I started to think that having the NAS be the PMS would be the way to go, but I’ve read through reviews that unless it has an actual desktop CPU, that transcoding would suffer and I wouldn’t be able to have subtitles on atom based units. And I do need subtitles.
Having the NAS unit be the PMS removes bandwidth problem, but then am I limiting the number of potential streams and possibly losing subtitles?
Having a PC for the PMS gives me the transcoding power I need, but I run the risk of bottlenecking the data.
Initial configuration thoughts
Plex PC:
Intel based SFF: Zotac Zbox (Beause it’s something I already own that has dual intergrated LAN)
NAS:
Synology DS1618+: 2 LAN ports set in Aggregate mode
Second configuration thoughts
PLEX/NAS:
Synology DS418play: 2 LAN ports set in Aggregate mode
Third configuration thoughts
PLEX/NAS
Not sure what the best option to go with is. And I don’t know linux at all, so trying to get NIC teaming and PLEX working on linux would be a challenge for me.
