Server Version#: Version 4.66.1
I have a small problem. I have 2 different films with a similar title but the same year.
Der Tag, an dem die Erde stillstand (2008)
and
Der Tag an dem die Erde stillstand 2 - Angriff der Roboter (2008).
Now, PLEX is showing both films as one and the same film. I don’t get the two films shown separately.
Does anyone have any tips on how to fix this?
Best way is to use tags so plex will know exactly how to match. So basically …
The Day the Earth Stopped (2008) {tmdb-16102}
However, I’m not sure there is a The Day the Earth Stopped 2, at least I could not find it but if you can then just use the tag for it. I also see in your screenshot the size of both movies are identical so I suspect its actually the same movie.
You might actually mean this movie but hard for me to tell as I try to translate
The Day the Earth Stood Still (2008) {tmdb-10200}
BTW… its HIGHLY recommended NOT to put all your movies on a flat folder structure. Use a folder per movie.
Oh thank you. The tip sounds good. I’m going to test that out. I already figured out how to separate the films earlier.
