Series Better ABsolute Scanner (S - BABS)
2.4.4 solve the issue
I can't seem to figure out how to add this scanner to PMS in freenas without breaking the jail. I am not getting any specific help from the freenas forums. Would anyone here help provide steps on how to install this scanner? Thanks.
https://forums.plex.tv/topic/19396-how-to-install-a-custom-scanner/
Hi guys, I hope you can help.
I have S-Babs running for my anime and am having some problems with one piece.
I recently added episodes 397-409 but they aren’t showing up in season 13 where they should be, instead they are listed in season 7 as duplicates of other episodes (13-25, or abs 104-116). The numbering is fine, TVDB id file is fine given the previous examples and i’m not sure what’s going on.
See Absolute Series Scanner (ASS) link in my signature. You could create a new library pointing to the same folders and use the “Absolute series scanner” on it, and tell me how if fares against it…
Are you using Hama agent ?
Thanks for the help.
I downloaded the scanner and agent and ran them both. Unfortunately the absolute listing in ASS doesn’t work well with my tv in terms of scrolling.
I loaded Hama into S-BABS and was still having trouble but found some funky meta-data in the files. Deleted that and it all worked out in the end. Thank you for the help.
hi, i moved all my media in new path, but when I do a rescan to discover the new path, all my OAV files are skipped and didn’t update the path.
this is the plex media scanner log, I can’t understand why (I use your scanner S-BABS for this section):
[~/Library/Plex Media Server/Logs] # cat "Plex Media Scanner.log"
Nov 25, 2015 14:00:26 [0xf2bffb90] INFO - Plex Media Scanner v0.9.14.3.1555-590ac74 - debian PC i686 - build: linux-debian-i686
Nov 25, 2015 14:00:26 [0xf2bffb90] INFO - Linux version: 3.12.6 (#1 SMP Wed Nov 18 07:06:32 CST 2015)
Nov 25, 2015 14:00:26 [0xf2bffb90] INFO - Processor Intel(R) Core(TM) i7-3770T CPU @ 2.50GHz
Nov 25, 2015 14:00:26 [0xf35df740] DEBUG - Opening 20 database sessions to library, SQLite 3.8.9, threadsafe=1
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - Scanning Cartoon using it(S-BABS) with 0 current media items in the database...
Nov 25, 2015 14:00:27 [0xf1fffb90] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/cullTimeline?librarySectionID=5&sinceTime=1448455227
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - Performing a scan with 'S-BABS' (language: it virtual: 0).
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - * Scanning /share/Multimedia/Video/Cartoons/Ken il Guerriero/OAV
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - * Scanning directory /share/Multimedia/Video/Cartoons/Ken il Guerriero/OAV (parent: yes)
Nov 25, 2015 14:00:27 [0xf35df740] VERBOSE - * Noting that 'Ken il Guerriero/OAV' was updated at 2015-11-25 14:00:19
Nov 25, 2015 14:00:27 [0xf35df740] VERBOSE - * Taking directory 'Ken il Guerriero/OAV' (250) out of the map (0 left)
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - Adding file for scanner: /share/Multimedia/Video/Cartoons/Ken il Guerriero/OAV/Ken il guerriero 0x08 - La leggenda di Toki - [1080p - AC3-DTS-Ita].mkv
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - Adding file for scanner: /share/Multimedia/Video/Cartoons/Ken il Guerriero/OAV/Ken il Guerriero 0x05 - La Leggenda Di Hokuto - [1080p - AC3-DTS-Ita-■■■].mkv
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - Adding subdirectory for scanner: /share/Multimedia/Video/Cartoons/Ken il Guerriero/OAV/.@__thumb
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - Adding file for scanner: /share/Multimedia/Video/Cartoons/Ken il Guerriero/OAV/Ken il Guerriero 0x01 - Il Film.avi
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - Adding file for scanner: /share/Multimedia/Video/Cartoons/Ken il Guerriero/OAV/Ken il guerriero 0x07 - La leggenda di Raoul - [1080p - AC3-DTS-Ita].mkv
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - Adding file for scanner: /share/Multimedia/Video/Cartoons/Ken il Guerriero/OAV/Ken il Guerriero 0x02 - La trilogia, La citta stregata.avi
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - Adding file for scanner: /share/Multimedia/Video/Cartoons/Ken il Guerriero/OAV/Ken il Guerriero 0x04 - La trilogia, Quando un uomo si fa carico della tristezza.mkv
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - Adding file for scanner: /share/Multimedia/Video/Cartoons/Ken il Guerriero/OAV/Ken il Guerriero 0x06 - La Leggenda Di Julia - [1080p - AC3-DTS-Ita]].mkv
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - Adding file for scanner: /share/Multimedia/Video/Cartoons/Ken il Guerriero/OAV/Ken il Guerriero 0x03 - La trilogia, La Tecnica Proibita.mkv
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - Adding file for scanner: /share/Multimedia/Video/Cartoons/Ken il Guerriero/OAV/Ken il guerriero 0x09 - La leggenda del Vero Salvatore - [1080p - AC3-DTS-Ita].mkv
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - File '/share/MD0_DATA/Multimedia/Video/Cartoons/Ken il Guerriero/OAV/Ken il Guerriero 0x01 - Il Film.avi' didn't exist, can't skip.
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - Removing 0 media items that were left.
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - Removing 0 directories that were left.
Nov 25, 2015 14:00:27 [0xf35df740] DEBUG - Updating directory 'Ken il Guerriero/OAV' (ID 250) to time 2015-11-25 14:00:19.
Nov 25, 2015 14:00:28 [0xf35df740] DEBUG - Refreshing section 5 of type: 2
suggestion?
working as designed.
use a naming convention for movies or OAVs supported by a SERIES scanner that supports movies in series libraries (not BABS) or label your movies in properly names flder and the file as s01e01…
