My Plex has suddenly stopped marking episodes that I’ve watched as just watched.
Can’t find a setting for this, it worked a week ago, and I haven’t changed anything.
If your client is PHT -> https://forums.plex.tv/discussion/comment/1206557/#Comment_1206557
What is PHT?
@dnilsson said:
What is PHT?
Plex Home Theater.
Ah
So Plex isn’t going to fix this issue, I need to get other software??
The next server update will actually contain a fix for the issue.
But since PHT will not get any new updates, it is time to change to a software which is still getting updates and new features.
Like OpenPHT or Plex Media Player.
Ok, thanks.
Is there a comparison of OpenPHT and Plex Media Player available somewhere??
No.
Just install them both and try them out. They can exist in parallel on the same computer.
@OttoKerner So this is a client issue? Just replaced my PMS on old NAS with version 1.00 on an intel NUC. However, the client is the same. Rasplex. Towards the NAS episeodes are marked as watched. But not towards PMS on NUC…
I am not sure what you did here.
Did you install two Plex servers, one on your NAS and one on your NUC?
If so, make sure your Rasplex is updated to the newest release. It shared the issue with PHT.
And if you play a movie on one server, it won’t get marked as played on the other.
@OttoKerner said:
@moje1977 said:
@OttoKerner So this is a client issue? Just replaced my PMS on old NAS with version 1.00 on an intel NUC. However, the client is the same. Rasplex. Towards the NAS episeodes are marked as watched. But not towards PMS on NUC…I am not sure what you did here.
If so, make sure your Rasplex is updated to the newest release. It shared the issue with PHT.And if you play a movie on one server, it won’t get marked as played on the other.
Yeah. In the process of replacing the NAS with NUC. In order to have better transcoding possibilities. But the episodes are not marked as watched on Rasplex/NUC when watched on Rasplex/NUC.
Sounds lika a combination of issues here; client and server versions…
If your Rasplex version is updated to V 1.6.2 there should be no issue.
