When trying to run high bitrate movies I get the error saying computer isn’t powerful enough to transcode. I run of local HDD and still get same error.
I have direct play on.
CPU i7 3930k (6core)
16GB RAM
Is there any other settings I can try to eliminate this problem? Also Playing through windows media player is fine.
Quite curious as to why you get that error though.
I run my server on a old Phenom II x6 1090t, which is quite a lot weaker than your 3930k.
Though I guess it depends a bit on how high the bitrate is. My machine has no issue with movies up to 20mbps in bitrate.
So the question is, how high is it?
Also have you tried changing transcoder settings to faster rather than quality?
