"Not enough CPU for conversion of this item" Error message,
High level view:
  • Unlimited max transcoders set in settings
  • Seems to only affect certain media/not all media affected.
  • Direct stream + Direct play are enabled
  • Issue happens on laptop + on Android TV as clients
  • Plex Server is in a Jail, in a FreeBSD box. No other current transcoding/playback sessions are happening on this specific server (ie: it’s idle). Cur ver: 1.21.1.3830
  • Enabling/Disabling HW Transcoding does not affect this.
  • CPU is Intel Celeron CPU J3455 @ 1.50GHz
Logs:
Jan 04, 2021 19:26:32.350 [0x80b53fc00] DEBUG - [Transcode] Found session GUID of 57f9d27c2bc9d1ab-com-plexapp-android in session start.
Jan 04, 2021 19:26:32.351 [0x80b53fc00] DEBUG - [Transcode] TranscodeUniversalRequest: using augmented profile Android
Jan 04, 2021 19:26:32.351 [0x80b53fc00] DEBUG - [Transcode] Downloading document http://127.0.0.1:32400/library/metadata/20838?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=<SNIP>
Jan 04, 2021 19:26:32.351 [0x80b53fc00] DEBUG - [Transcode] Auth: authenticated user 1 as <SNIP>
Jan 04, 2021 19:26:32.356 [0x80b53fc00] DEBUG - [Transcode] We're going to try to auto-select an audio stream for account 1.
Jan 04, 2021 19:26:32.356 [0x80b53fc00] DEBUG - [Transcode] Selecting best audio stream for part ID 23008 (autoselect: 1 language: en)
Jan 04, 2021 19:26:32.356 [0x80b53fc00] DEBUG - [Transcode] Audio Stream: 24169, Subtitle Stream: -1
Jan 04, 2021 19:26:32.356 [0x80b53fc00] DEBUG - [Transcode] Scaled up video bitrate to 1441Kbps based on 1.500000x fudge factor.
Jan 04, 2021 19:26:32.357 [0x80b53fc00] DEBUG - [Transcode] MDE: Selected protocol hls; container: mkv
Jan 04, 2021 19:26:32.357 [0x80b53fc00] DEBUG - [Transcode] MDE: analyzing media item 22996
Jan 04, 2021 19:26:32.357 [0x80b53fc00] DEBUG - [Transcode] MDE: E2 - Soul Hunter: Direct Play is disabled
Jan 04, 2021 19:26:32.357 [0x80b53fc00] DEBUG - [Transcode] MDE: E2 - Soul Hunter: media must be transcoded in order to use the hls protocol
Jan 04, 2021 19:26:32.357 [0x80b53fc00] DEBUG - [Transcode] MDE: E2 - Soul Hunter: no direct play video profile exists for http/avi/msmpeg4v3
Jan 04, 2021 19:26:32.357 [0x80b53fc00] DEBUG - [Transcode] MDE: E2 - Soul Hunter: no direct play video profile exists for http/avi/msmpeg4v3/ac3
Jan 04, 2021 19:26:32.357 [0x80b53fc00] DEBUG - [Transcode] MDE: E2 - Soul Hunter: avoiding video remux due to potentially unsafe container/codec combination
Jan 04, 2021 19:26:32.357 [0x80b53fc00] DEBUG - [Transcode] MDE: E2 - Soul Hunter: no remuxable profile found, so video stream will be transcoded
Jan 04, 2021 19:26:32.357 [0x80b53fc00] DEBUG - [Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
Jan 04, 2021 19:26:32.357 [0x80b53fc00] DEBUG - [Transcode] Scaled up video bitrate to 1441Kbps based on 1.500000x fudge factor.
Jan 04, 2021 19:26:32.357 [0x80b53fc00] DEBUG - [Transcode] MDE: Babylon 5 - S1 E2 - Soul Hunter: selected media 0 / 22996
Jan 04, 2021 19:26:32.357 [0x80b53fc00] DEBUG - [Transcode] Streaming Resource: Reached Decision id=20838 codes=(General=2000,Neither direct play nor conversion is available. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=4002,Not enough CPU for conversion of this item.)
Jan 04, 2021 19:26:45.355 [0x80b53fc00] DEBUG - Request: [192.168.0.26:65192 (Allowed Network (Subnet))] GET /player/proxy/poll?deviceClass=pc&protocolVersion=3&protocolCapabilities=timeline%2Cplayback%2Cnavigation%2Cmirror%2Cplayqueues&timeout=1 (12 live) TLS GZIP Signed-in Token (<SNIP>)
Jan 04, 2021 19:26:45.355 [0x80b53fc00] DEBUG - Content-Length is -1 (of total: -1).
XML for this specific media:
<MediaContainer size="1" allowSync="1" identifier="com.plexapp.plugins.library" librarySectionID="2" librarySectionTitle="TV Shows" librarySectionUUID="ce029ebc-4d6b-4050-a7c2-10e1b1198283" mediaTagPrefix="/system/bundle/media/flags/" mediaTagVersion="1608234898">
<Video ratingKey="20838" key="/library/metadata/20838" parentRatingKey="20835" grandparentRatingKey="20834" guid="com.plexapp.agents.thetvdb://70726/1/2?lang=en" parentGuid="com.plexapp.agents.thetvdb://70726/1?lang=en" grandparentGuid="com.plexapp.agents.thetvdb://70726?lang=en" type="episode" title="Soul Hunter" grandparentKey="/library/metadata/20834" parentKey="/library/metadata/20835" librarySectionTitle="TV Shows" librarySectionID="2" librarySectionKey="/library/sections/2" grandparentTitle="Babylon 5" parentTitle="Season 1" contentRating="TV-PG" summary="A badly damaged ship is brought into the station and the strange alien inside is identified as a soul hunter - an immortal race who can sense death and supposedly steal someone's soul." index="2" parentIndex="1" rating="7.3" year="1994" thumb="/library/metadata/20838/thumb/1609706537" art="/library/metadata/20834/art/1609706574" parentThumb="/library/metadata/20835/thumb/1609706570" grandparentThumb="/library/metadata/20834/thumb/1609706574" grandparentArt="/library/metadata/20834/art/1609706574" grandparentTheme="/library/metadata/20834/theme/1609706574" duration="2525504" originallyAvailableAt="1994-02-02" addedAt="1609706456" updatedAt="1609706537">
<Media id="22996" duration="2525504" bitrate="1153" width="640" height="368" aspectRatio="1.78" audioChannels="2" audioCodec="ac3" videoCodec="msmpeg4v3" videoResolution="sd" container="avi" videoFrameRate="PAL">
<Part accessible="1" exists="1" id="23008" key="/library/parts/23008/1609705503/file.avi" duration="2525504" file="/TV/Babylon 5/Season 1/b5.102-amc.avi" size="365930496" container="avi" deepAnalysisVersion="4" requiredBandwidths="1397,1397,1397,1397,1397,1397,1397,1397">
<Stream id="24168" streamType="1" codec="msmpeg4v3" index="0" bitrate="961" bitDepth="8" chromaSubsampling="4:2:0" codedHeight="368" codedWidth="640" frameRate="25.000" height="368" refFrames="1" requiredBandwidths="1214,1214,1214,1214,1214,1214,1214,1214" width="640" displayTitle="SD (MSMPEG4V3)" extendedDisplayTitle="SD (MSMPEG4V3)"> </Stream>
<Stream id="24169" streamType="2" selected="1" codec="ac3" index="1" channels="2" bitrate="192" audioChannelLayout="stereo" requiredBandwidths="192,192,192,192,192,192,192,192" samplingRate="48000" streamIdentifier="1" displayTitle="Unknown (AC3 Stereo)" extendedDisplayTitle="Unknown (AC3 Stereo)"> </Stream>
</Part>
</Media>
<Writer id="20094" filter="writer=20094" tag="J. Michael Straczynski"/>
<Marker type="intro" startTimeOffset="122933" endTimeOffset="206712"/>
<Extras size="0"> </Extras>
<Related> </Related>
</Video>
</MediaContainer>
Any help would be appreciated.
MSMPEG4V3 is an old codec. There are some encoders that created crazy versions of these files. The transcoder may not be able to handle all of these crazy formats. I would recommend running these files through an encoder (if you can find one that works) and changing them to something else.
