Server Migration Results In Unsecure Connection
Server Version#: plexinc/pms-docker:latest
Player Version#: plex.tv
Hey,
Following the Hetzner ban, I migrated my Plex install to a new server.
After moving all the docker data and starting the server I’m able to access my server directly and I see that remote access is enabled and working.
However, access from plex.tv or any of the other Plex apps results in no connection and I get a message saying that Plex is unable to connect securely.
I tried to enable and disable secure connections to maybe trigger a new certificate to be generated for my new server however it was unsuccessful.
I suppose this is a certificate problem, I might need a new certificate to be generated but I’m not entirely sure.
Attaching server logs to help further diagnosis.
Plex Media Server Logs_2023-12-10_20-53-03.zip (527.8 KB)
Thanks,
Tom
Hey,
The problem persists and after following even more of the help guides ai can’t get the connection to be secure.
This is running on an OVH dedicated server, and with the same exact config on my previous Hetzner server but for some reason it can’t establish a secure connection.
Could it be a certificate issue?
Thanks,
Tom
