Server Version#: 1.42.2.10156
Player Version#: webclient
Oct 08, 2025 09:37:49.521 [127589309172536] DEBUG - CERT: incomplete TLS handshake from [::ffff:x.x.x.x]:35016: sslv3 alert certificate unknown (SSL routines)
Oct 08, 2025 09:37:56.319 [127589307063096] WARN - [CERT] TLS connection from [::ffff:x.x.x.x]:35026 came in with unrecognized plex.direct SNI name ‘10-99-99-xxx.plex.direct’; using installed plex.direct cert
if i claim the server, it will break and only show “Not Authorized”. after removing the fields from Preferences.xml it will starts workking again.
it’s a fresh installation on proxmox LXC with the community scripts.
i access the server via localhost with tunnel and local ip. always the same.
now, i have solved the issue. i deleted the plexonline variables from preferences.xml and delete Cache/, restart, ssh tunnel to the host, open the plex page with localhost. now i can access the server settings. claim server - ok this time. changed url to plex.tv. looks like i cann access the server. but it cannot activate remote access. i already set the manual port to 32400.
and when i want to play a movie i get “Error code: s1001 (Network)”. i never had this issues bevor in my installations…
this is a fresh install on a new server. should i start from scratch?
