Server Version#:1.21.1.3830
My Raspberry PI 3 B, I can’t load libraries, among other things the raspberry server settings are not available as you can see below. I would love to try an old c’versiobne to see if it works, but when I try to download packages from the repository, it always updates to the latest version.
Log:
● plexmediaserver.service - Plex Media Server
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2021-01-08 16:17:10 CET; 2 days ago
Process: 515 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" (code=exited, status=0/SUCC
Main PID: 520 (Plex Media Serv)
Tasks: 56 (limit: 2063)
CGroup: /system.slice/plexmediaserver.service
├─ 520 /usr/lib/plexmediaserver/Plex Media Server
├─ 683 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-6c22540d5/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.21
└─1081 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.21.1.3830-6c22540d5 32600 /waitmu
gen 10 16:23:30 raspberrypi Plex Media Server[520]: Error starting framework core for /usr/lib/plexmediaserver/Resources/Plug-ins-6c22540d5/PlexMovie.bundle.
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
