Server Version#:1.43.5.11079-3b313
Player Version#:2026.22.0 (971050578)
so i run plex server on my asustor as3304t and use a nvidia shield to watch my ripped movies and tv series. have been for several years.
i maintain it all through my laptop .
since yesterday there has been no access to my libraries on shield, laptop or phone.
they all say unavailable. i can however reach them through emby which works no problem,
when i try the https:/nasip/32400 route it won’t connect, site is refusing to connect.
@veeejay kindly pointed me towards cache directory and changing a file name, certificate12, but i can’t find the file. should it be on the nas?
any help, the simpler the better, much appreciated
Where did I direct you to do this? I just asked if you can hit your server directly via ip and port in the other thread.
This likely means the Plex service isn’t running on your NAS. Did you confirm it’s started? Based on this, the cert step you mentioned isn’t relevant.
Are you on YouFibre? Just asking because of an issue that impacts AT&T has also impacted YouFibre in the UK and Bell Fiber in Canada in the past year or so. Basically a firmware update gets pushed to the isp provided gateway and locally clients cant connect to the plex server over port 32400 anymore. You have to disable remote access and remove any port forward and disable UPnP to get it to work locally again. The option for AT&T and YouFibre is to get your own router, and either bridge/passthrough theirs or ditch theirs entirely for your own.
If you’re not on YouFibre, you’ll need to check your network setup for any isolation settings to confirm nothing is blocking your connections. You should be able to hit the plex server directly via ip and port if the service is running.
You’ve tried the direct ip, http://<nasip>:32400/web from multiple browsers/devices? Try both http and https and make sure you have /web at the end.
Have you gone to the logs directory in the Plex Media Server folder to confirm no issues with the startup of the server?
