Hi I get as far as the below screen, Enter English but nothing works from there. Continue button is greyed ou. I dont get prompted for a Zip code.
Note. I am in New Zealand, and PLEX is running on a Synology NAS.
What version of PMS do you have installed? Also what country/ZIP Code/postal code are you using?
Unfortunately Plex does not support live TV/DVR in New Zealand. You’ll need to install an external EPG. If you search on New Zealand in the forums you will probably find what you need.
Thanks. I was suspecting that that might be the issue. Will do some Googling.
Many thanks.
