Another day, another post about Live TV/DVR.
I want to list out the issues I’m having to try and keep them all in one place. Some of these issues have already been posted to the forums, but other than the threads about time-shifting being broken, the others haven’t received much attention if any at all.
1. Time-Shifting Is Completely Broken
Time-shifting in general is broken. Trying to play a recording that is already in progress is a hot mess. Anytime I try to do this, I’m taken to live portion of the recording and unable to successfully seek back to the beginning.
Yesterday, while I was home for lunch, I was watching a program live. I paused the program during the commercial break so I could catch the end of the segment, but when I came back to the TV after 5-10 minutes, there was a message on the screen instructing me to hit play to resume live TV. When I hit play, I can only assume I was now watching live (as it didn’t resume from where I paused it), but the progress bar showed a different time-stamp. Trying to seek backwards worked, but because it showed the wrong progress within the program, I couldn’t get back to where I was when I paused it.
2. Live TV on Roku has Playback Issues
When watching live TV from a Roku client, the stream will eventually start to buffer, but usually get stuck on 33% before failing and then displaying an error message about signal quality. 1 times out of 10, the stream will actually begin to resume playback instead of completely failing. There are numerous threads about this issue, but I haven’t seen any feedback from Plex on those threads.
I will add that I am using an HDHR Prime with a cable subscription, so signal quality isn’t the actual issue. Also, I am direct streaming these channels within Plex. Disabling MPEG2 in the Plex client settings will force the channels to transcode and limits this from happening, but it still does occur.
There is no pattern to the live stream errors out. Sometimes I can be watching a stream for 30 minutes to an hour (or even longer) with no issues before it finally breaks, or other times it can be 5 minutes.
When playing these channels in the new HDHomeRun app for Roku, no playback issues occur. Furthermore, when playing a DVR recording back within Plex on a Roku client (with MPEG2 support enabled), no buffering or other playback issues occur. It only happens when playing a live TV stream.
3. EPG on Android Mobile Broken
I often try to schedule recordings from the Plex Android client. When searching for a program, the airdates are often shown as December 31st. If I set the program to record, it will record as expected, but it’s very annoying to not know when a program is actually going to air. Sometime I want to use the mobile app to just browse the EPG, not necessarily to always set a recording, and I’m unable to do so for some programs because of this bug. I’ve also seen this bug mentioned within some of the other threads involving the new EPG issues, but again, I haven’t seen any acknowledgment from Plex.
4. General EPG Issues
The EPG issues that first plagued me during the switch of providers have finally started to calm down, but there are still some issues I’ve been noticing. The biggest issue involves season and episode numbers. It’s getting better, but it’s still hit or miss whether a program has the correct season and episode number. On the same program, it seems to be correct one week, but not the next. This causes issues with scheduled recordings.
Another little concern is that some channels are missing logos in the grid guide. Obviously a lower level complaint, but still a little annoying.
I can recreate and provide logs for any of the issues I listed above. If anyone else is experiencing these issues, I’d appreciate additional comments that may help us get this nailed down so Plex can hopefully get them resolved.
Again, I know many of these issues have been posted before, but I wanted to gather all of my specific issues in one thread as they all relate to live TV/DVR. Hopefully I can get some direct feedback from Plex as some of these issues have gone unanswered.
