Sharing library and played episodes on deck
I’m sharing my libraries with about 15 users on my Plex Server on NAS Synology (Films & Series).
Sometimes, my friends are watching some series and these series appear on my deck but I’m not watching them right now… And these series was marked as watch ! It’s more annoying when I’m watching the same serie and my friend is watching the season 4 when I’m in the season 2 for exemple…
Is it normal or is there any issues about that ??
If you look at the dashboard and look at play history are things correct there, as far as who watched what.
It almost sounds to me like someone is using your login instead of their own… Are these invited accounts, or are they home user accounts?
Any chance you are using the old trakt.tv plugin?
Hi !
I’m pretty sure that noone are using my account because I’ve got Tautulli and I put some notifications and for exemple a friend has just started a new serie that I put and with his own account and now, I see this serie on my Deck. All friend are using their own account.
Indeed, I tried a trakt.tv plugin and I put it with WebTools. Do you think trakt.tv make me theses issues ?
Yes. Disable it because you cannot configure it anymore to not scrobble your kids’ playbacks. (Which then get synced back from Trakt to your Plex account)
