I recently approved a friend request, but when I try to share my library, I am geting a 422 error. Another weird thing is when I click on the share library, her name is listed in the friends without access, but when I click on her name… the continue button is still greyed out. But when I search for her name and then click on it in the filtered list in the my friends without access… then I can click the continue button. But when I try and share ALL Libraries, just movies, or just tv… I always get a 422 error. Haven’t had any issues before sharing my libraries. Any help would be appreciated. Thanks. (Have tried un-friending and then re-friending too. Still same 422 error)
plex failed with 422
How many friends?
Error 422 means you’ve reached the sharing limit of 99 friends.
Are you using the hosted web app to grant the access?
You must not use the local web app.
I was using the website plex.tv to grant access and I only have a dozen or so friends/shares. So, dont think it was either of those. Weird thing, I just checked plex and now the account is shared and has library access and I can add/remove access without error now. I havent done anything since I got the 422 errors, but somehow plex fixed itself.
Thanks all!
I am getting this error 422 as well and I am trying to share with my second person. Not at the limit or even close to it.
I have the same problem, with only one friend. I try to grant library access to friend via “app.plex.tv”, and get “There was an unexpected error” after click submit button.
