Shield Edit Recording Settings Bug
Server Version#: 1.32.7.7621
Player Version#: 10.4.0.4843
Tuner Make/Model: HDHomeRun Quatro
Can no longer edit the programmed recording settings in V10.4.0.4843 running on Shield from the Live TV > DVR Schedule > Recording Priority tab.
@sa2000 Any update on this bug fix?
Surely I can be the only one to notice this.
A fix is coming out in 10.5.0 which I think is already out as beta
Sorry - just noticed you mentioned DVR Priority
Are you able to modify recordings showing on the DVR schedule ?
I will need to look further
OK the problem with modifying recording is being fixed in 10.6.0
A problem with watching whilst recording is being fixed in 10.5.0
Thank you for checking, sorry if I was not clear.
Yes, once you program a recording it cannot be modified in the Recording Priority tab. Don’t know how this happened as it was working perfectly before as I use this feature all the time. Currently, I have to modify recordings on my phone or web app until this bug gets fixed.
As you advised, I’ll be waiting on 10.6.0
I have exactly the same problem on my shield server. I was just learning how to schedule recording and selected a few series to record, so now I can’t delete the scheduled recording through any means that I know of. There isn’t an “agenda” view in my DVR Live TV view menu area that supposedly allows deleting series. I’ll try to go through the server and bumble around until I figure out something. New to Plex and New to the server environment too…
I’m just glad that someone seems to be aware of the issue.
