SHIELD hardware transcoding problem?
Currently using PMS Beta 5063. On Beta and Stable versions, i often encounter conversion issues on Mobile Sync when HW transcoding is selected, usually “The transcoder encountered an error” or “The transcoder cannot process this media”. However, when i untick HW transcoding, the conversion will take longer, but usually will work fine. I would like to use HW transcoding, however i can’t seem to find any errors in my logs. Has anyone encountered the same issue?
If you could provide a sample of the affected media, alongside some logs from when it occurs, that would be really helpful! :slight_smile:
Hi there, sorry for taking so long to reply. The below part of the PMS log is all i can identify as the source of the problem. There are no other TPU errors. I followed the conversion process in the web app with HW transcoding on, and there were no errors displayed. However, i received an error on the Android device i am syncing to saying “Unable to Process Media” and “The transcoder encountered an error”. I retried again with HW transcoding off, and the Sync happened successfully. I have attached an XML of the affected media.
My Plex Media Server V1.13.2.5102 is on a Shield (2017) 16GB running Shield Experience 6.3 which should be HW transcoding capable according to your support files.
May 30, 2018 09:16:52.674 [3378] DEBUG - MDE: analyzing media item 6977
May 30, 2018 09:16:52.674 [3378] DEBUG - MDE: E4 - Ghosts of Christmas Future: no direct play video profile exists for http/mkv/h264
May 30, 2018 09:16:52.674 [3378] DEBUG - MDE: E4 - Ghosts of Christmas Future: no direct play video profile exists for http/mkv/h264/eac3
May 30, 2018 09:16:52.674 [3378] DEBUG - MDE: E4 - Ghosts of Christmas Future: selected sidecar subtitle stream cannot be direct played
May 30, 2018 09:16:52.674 [3378] DEBUG - Ghosts of Christmas Future - video.width limitation applies: 1920 > 1280
May 30, 2018 09:16:52.674 [3378] DEBUG - MDE: E4 - Ghosts of Christmas Future: selected subtitle cannot be converted to a compatible format, burning into video stream
May 30, 2018 09:16:52.674 [3378] DEBUG - MDE: E4 - Ghosts of Christmas Future: avoiding video remux due to burned subtitle stream
May 30, 2018 09:16:52.674 [3378] DEBUG - MDE: E4 - Ghosts of Christmas Future: no remuxable profile found, so video stream will be transcoded
May 30, 2018 09:16:52.674 [3378] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
May 30, 2018 09:16:52.674 [3378] DEBUG - Scaled up video bitrate to 15891Kbps based on 1.500000x fudge factor.
May 30, 2018 09:16:52.674 [3378] DEBUG - Scaled maximum bitrate for resolution reduction to 7062Kbps.
May 30, 2018 09:16:52.674 [3378] DEBUG - MDE: Cannot direct stream audio stream due to codec eac3 when profile only allows aac
May 30, 2018 09:16:52.675 [3378] DEBUG - MDE: E4 - Ghosts of Christmas Future: selected media 0 / 6977
May 30, 2018 09:16:52.689 [3398] DEBUG - Downloaded stream from [127.0.0.1:32400/library/streams/13529?X-Plex-Token=xxxxxxxxxxxxxxxxxxxx] (codec: srt) to temporary file [/sdcard/Download/Transcode/Sessions/plex-transcode-07b39665-ab92-412e-9b6f-44133aebdac1-cac5d19c-89ef-4f16-9fd1-69a5a7b7a510/temp-0.srt]
May 30, 2018 09:16:52.690 [3398] DEBUG - TPU: hardware transcoding: zero-copy support not present
May 30, 2018 09:16:52.690 [3398] DEBUG - TPU: hardware transcoding: final decoder: mediacodecndk, final encoder: mediacodecndk
@philiptruong Would you be able to share a sample of the actual media file?
Any suggestion how to do this to retain the same file characteristics?
@philiptruong Generating Sample Files from Media | Plex Support :wink:
after reading this I thought I give optimisation on my shield another try while disabling hardware transcoding (optimising on shield newer worked): and voilà! success :smile:
This is currently happening to me also and only started to occur in the last update both stable and beta. This is definitely and ongoing issue and I am struggling to figure out why. It also has no errors in the log.
Though I also apparently cannot upload anything to this forum at the moment either.
Any idea on a fix?
@DaveBinM i’ve cut a sample of the affected media: https://www.dropbox.com/s/ha080o024dhhwwn/Sample.mkv?dl=0
I tried to optimize it in PMS on my Shield, it stays stuck on Converting at 100%.
As @UncleGadget above mentions, i tried to optimize the affected media with HW transcoding ON, and the optimization fails. However, with HW transcoding OFF, the optimization completes.
I had a look in the logs and found this error: “TPU: hardware transcoding: enabled, but no hardware decode accelerator found”.
@philiptruong Thanks for the sample. I’ll try and reproduce on my side with my Shield. :+1:
@philiptruong Thanks for the sample. We’ve been able to replicate on our side, and are investigating further.
@DaveBinM glad that you can replicate the issue. This is not the only file that is affected, i have the same problem with various files from different shows and programs. Right now, the only way i can use sync on my Shield is with HW transcoding OFF.
@philiptruong We’re tracking this internally now and will continue to investigate :slight_smile:
@DaveBinM any results from your investigation?
@philiptruong I’ve passed it along to engineering now, so it’s just a matter of time and resourcing. Sorry I can’t provide anything further! :slight_smile:
@philiptruong Can you upload your sample again? We were looking into this today, but found your sample was no longer there. Thanks!
Here you go https://www.dropbox.com/s/9g0ogmcidycb5ky/SEAL%20Team%20-%20S01E04%20-%20Ghosts%20of%20Christmas%20Future%20WEBDL-1080p%20(Split)-001.mkv?dl=0
Thank you!
no problem, hope you issue a fix soon!
Anything? This has been going on for a couple of months now…
