Shield TV client crashes when opening an item
v 6.14.0.3499
When I try to open a particular item from dashboard, the client keeps crashing. It contains 2 media files. They open fine on web client
Logs & xml of items attached
I’ve tried optimise database & reboots to no avail
Not sure if useful but just to add that this is a DVR recording & it’s optimised version
Thanks for reporting, can you clarify if you only see this on a particular file and not all of your videos?
Moved your thread into the beta forums as it’s not relevant to the public release.
Just on this file
Would you be able to create a sample of the file and we can investigate why it’s crashing?
@stuartf1 said:
Just on this file
If it’s an mkv split it with mkvtoolnix into a 30s sample.
Unfortunately I’ve since deleted these files. I’ll keep an eye out for a
repeat & will do this. Thanks
