When browsing the movie library, I can’t seem to figure out how to jump an entire page at a time. Scrolling through 300+ movies one at a time is very tedious. I’ve searched though the forums/Google and can’t seem to find anything.
I use a Harmony Elite remote in an activity that contains a Media Center Keyboard device against a MCE IR USB adapter.
@eugovector What is the device you have in your Harmony activity? I have tried a few different ones (Media Center PC SE/MCE Keyboard/Media Center PC) and none seem to work.
Personally I control mine via bluetooth. I configured it as Entertainment Device -> Microsoft/Kodi. This has most of the configuration you’d want by default set (such as page up/down). Also the bluetooth is more responsive and accurate (if you hit left 5 times in rapid succession, it moves left exactly 5 times, every time). Then you can configure other buttons to send different commands or you can configure the .plexht/userdata/keymaps/keyboard.xml to do certain actions. I do subtitle cycling through those (the colored buttons across the top send a-d). Here is my file:
I’m assuming you’re using a USB bluetooth module. Which do you use?
@gbooker02 said:
Personally I control mine via bluetooth. I configured it as Entertainment Device → Microsoft/Kodi. This has most of the configuration you’d want by default set (such as page up/down). Also the bluetooth is more responsive and accurate (if you hit left 5 times in rapid succession, it moves left exactly 5 times, every time). Then you can configure other buttons to send different commands or you can configure the .plexht/userdata/keymaps/keyboard.xml to do certain actions. I do subtitle cycling through those (the colored buttons across the top send a-d). Here is my file:
Ah. It would probably be helpful if I listed my components/setup. :-\
Dell OptiPlex 9020
Windows 8.1 Pro w/Media Center
Ceton InfiniTV 6 Eth
Microsoft USB IR Receiver
Harmony Elite Remote
I also use EventGhost to change mappings depending on what application is currently running. I have tried keeping EventGhost closed and just using the existing mapping of ChannelUp/Down on the Harmony remote but nothing works.
I tried a number of Media Center devices, and all seemed to work about identically. Looks like I land on “Microsoft Windows Media Center” as the one I finally chose.
Dell OptiPlex 9020
I’m on an Odroid C2, not a windows computer, but I’ll explore Bluetooth control a bit. Looks like we’re still waiting for the perfect Plex client.
