ShortsTV
Apparently ShortsTV is available on Plex (acccording to ShortsTV website) but I don’t see how to access it.
Does anyone know how I can access the channel?
If I had to wager, it’d be one of Plex’s “Live TV” channels. If you haven’t already, enable “Live TV” in your account’s “Online Media Sources” menu, then find the “Live TV” in your pinned/unpinned list on the left side of the main menu. If you do not have something labeled “Live TV”, then you must click on “more” and you will find it under the “Plex” category, rather than a server-based source).
Once you found it, click it and browse the channel list. Make sure you are showing Plex’s offerings by clicking the dual-bar icon near the top of the page and verify that “Plex Channels” is checked. If you have a tuner of your own, this list will also show your own channels, which I recommend disabling for now to narrow down the choices.
Here, I seem to have gotten lost. After reading each tiny channel logo, for the word “Choice”, I gave up after 5 minutes of slow scrolling. It’s possible that it is here, but I got bored of doing so, but I bet it is here. If you know what kind of content that “Shorts” has on Plex, you could try the categories sections to narrow down the selection somewhat, or even use the search bar at the top for a specific program to find the channel.
FYI, according to this page, their content on Plex is labeled “Shorts” or “CORTOS” for their Spanish channel:
ShortsTV’s advertising-supported connected TV channels SHORTS and CORTOS (in Spanish) are available on [Plex] and [Sling TV.]
