Is there any way to have LOCAL extras listed before the ones Plex finds on line? If I go to the trouble of adding my own extras, I would very much like to see them listed FIRST instead of LAST as they currently seem to be. For reference, I was just observing this with a movie I just added in the web browser player interface (using Chrome on Windows, FWIW) and I may have also noticed it when using my Roku 3 as well (not positive about that one right now, though.) Please tell me there is an option somewhere to list local stuff before on line or vice-versa!
This too is determined by the order of the metadata agents.
If you want ‘Local Extras’ to appear first, you need to have
‘Local Media Assets’ in the topmost position under
- Settings - Server - Agents - Movies - Plex Movie
- Settings - Server - Agents - Movies - TheMovieDatabase
This however does also give priority to embedded metadata. So you better make sure that all of your mp4 files either have none, or 100% correct embedded metadata.
Thanks for the info. Hopefully these two different things will be disconnected in the future. Until then, it works like it works.
