Where do movie "extras" come from?
These aren’t local, I’m pretty sure. If I add local featurettes, will they be prioritized?
Yes, local extras are generally sorted first.
With one exception: if there is no trailer among your local extras, the one supplied by Plex will appear first.
If you are supplying your own trailer, you might also want to start its name with an early letter in the alphabet, to make sure it is sorted before the other trailers.
That’s dope. Thanks for the info
